setup qtplasmac
  • fupeama
  • fupeama's Avatar Topic Author
  • Senior Member
  • Senior Member
13 Jul 2021 12:18 #214561 by fupeama
Replied by fupeama on topic setup qtplasmac
Yup, me too, but cutting 20mm plates with plasma is the "industrial" domain requiring 5 and 6 figure price tags.
On the other hand, adding an Oxy Acetylene torch to the plasma machine does that easily and with style! :)
yes -  for thicker material is better use oxy Acetylene. in the future i would like to be able to replace the plasma torch with oxy acetylene. I'm currently studying how to set it all up.
Martin
  • fupeama
  • Senior Member
  • Senior Member
16 Jul 2021 12:17 #215032 by fupeama
The final decision for the ARC override was made on the keyboard and the plus, minus and reset keys on external panel.
I modified the handler a bit. Now I am happy with this solution.
share/qtvcp/screens/qtplasmac/qtplasmac_handler.py
index 56cf3f251..cfcda3a5b 100644
@@ -432,6 +432,9 @@ class HandlerClass:
         self.colorFgPin = self.h.newpin('color_fg', hal.HAL_S32, hal.HAL_OUT)
         self.cutTypePin = self.h.newpin('cut_type', hal.HAL_S32, hal.HAL_IN)
         self.heightOverridePin = self.h.newpin('height_override', hal.HAL_FLOAT, hal.HAL_OUT)
+        self.heightOverridePinPlus = self.h.newpin('height_override_plus', hal.HAL_BIT, hal.HAL_IN)
+        self.heightOverridePinMinus = self.h.newpin('height_override_minus', hal.HAL_BIT, hal.HAL_IN)
+        self.heightOverridePinReset = self.h.newpin('height_override_reset', hal.HAL_BIT, hal.HAL_IN)
         self.laserOnPin = self.h.newpin('laser_on', hal.HAL_BIT, hal.HAL_OUT)
         self.materialChangePin = self.h.newpin('material_change', hal.HAL_S32, hal.HAL_IN)
         self.materialChangeNumberPin = self.h.newpin('material_change_number', hal.HAL_S32, hal.HAL_IN)
@@ -1248,6 +1251,15 @@ class HandlerClass:
         self.heightOverridePin.set(self.heightOvr)
         self.w.height_ovr_label.setText('{:.2f}'.format(self.heightOvr))
+    def heightOverridePinIn (self,state,value):
+        if state:
+            if value:
+                self.heightOvr += value * self.w.thc_threshold.value()
+            else:
+                self.heightOvr = 0
+        if self.heightOvr > 10 : self.heightOvr = 10
+        if self.heightOvr < -10 : self.heightOvr = -10
     def touch_xy_clicked(self):
         self.touch_off_xy(0, 0)
         self.w.gcodegraphics.logger.clear()
@@ -1813,6 +1825,9 @@ class HandlerClass:
         self.w.laser.pressed.connect(self.laser_pressed)
         self.w.main_tab_widget.currentChanged.connect(lambda w:self.main_tab_changed(w))
         self.zHeightPin.value_changed.connect(lambda v:self.z_height_changed(v))
+        self.heightOverridePinPlus.value_changed.connect(lambda v:self.heightOverridePinIn(v,1))
+        self.heightOverridePinMinus.value_changed.connect(lambda v:self.heightOverridePinIn(v,-1))
+        self.heightOverridePinReset.value_changed.connect(lambda v:self.heightOverridePinIn(v,0))
         self.plasmacStatePin.value_changed.connect(lambda v:self.plasmac_state_changed(v))
         self.w.feed_label.pressed.connect(self.feed_label_pressed)
         self.w.rapid_label.pressed.connect(self.rapid_label_pressed)
Martin
17 Jul 2021 07:26 #215120 by phillc54
Replied by phillc54 on topic setup qtplasmac
Great work. If you want to submit a PR to include the work I would be happy to merge it.
If you want to do a PR you would just need to make some minor changes to keep the code consistent with the existing. Also it would be better to rework the exising height_ovr_pressed function so both the GUI buttons and the external Hal pins use the same function rather than having two functions doing the same job.
  • fupeama
  • Senior Member
  • Senior Member
19 Jul 2021 08:45 #215295 by fupeama
Ok, I tried to make PR. I did it for the first time, so maybe it works.
Martin
19 Jul 2021 09:02 #215297 by phillc54
Martin
I saw the PR, it looks good, I will test and merge tomorrow.
It would have been nice if you had renamed the pins so they were similar to the existing external pins, something like:
self.extHeightOvrMinusPin
Do you want to add them to the doc or do you want me to.
  • fupeama
  • Senior Member
  • Senior Member
19 Jul 2021 10:27 #215307 by fupeama
OK I will rename pin.
something like this?
self.extHeightOvrPlusPin = self.h.newpin('ext_height_ovr_plus', hal.HAL_BIT, hal.HAL_IN)I would prefer you to add the information to the documentation because English is not my native language.
Martin
19 Jul 2021 10:34 #215309 by phillc54
Great, thanks for doing this. I'll do the docs tomorrow as well.
  • fupeama
  • Senior Member
  • Senior Member
21 Jul 2021 14:38 #215497 by fupeama
Thanks for adding code to repo.
If you want, I can try write code for encoder height override too.
Martin
21 Jul 2021 23:22 #215532 by phillc54
Martin
I am not sure what you mean, but I would be happy to have a look.
  • fupeama
  • Senior Member
  • Senior Member
22 Jul 2021 07:30 #215553 by fupeama
similar feature like a buttons but for encoder.
I think the source code is explanatory
Martin.
index 521dc682e..40c4ad0df 100644
@@ -208,6 +208,7 @@ class HandlerClass:
         self.dialogError = False
         self.cutTypeText = ''
         self.heightOvr = 0.0
+        self.old_ovr_counts = 0
         self.startLine = 0
         self.preRflFile = ''
         self.rflActive = False
@@ -474,6 +475,10 @@ class HandlerClass:
         self.extHeightOvrMinusPin = self.h.newpin('ext_height_ovr_minus', hal.HAL_BIT, hal.HAL_IN)
         self.extHeightOvrResetPin = self.h.newpin('ext_height_ovr_reset', hal.HAL_BIT, hal.HAL_IN)
+        self.extHeightOvrCountsPin = self.h.newpin('ext_height_ovr_counts', hal.HAL_S32, hal.HAL_IN)
+        self.extHeightOvrCountEnablePin = self.h.newpin('ext_height_ovr_count_enable', hal.HAL_BIT, hal.HAL_IN)
         self.probeTestErrorPin = self.h.newpin('probe_test_error', hal.HAL_BIT, hal.HAL_IN)
         self.out0Pin = self.h.newpin('ext_out_0', hal.HAL_BIT, hal.HAL_OUT)
         self.out1Pin = self.h.newpin('ext_out_1', hal.HAL_BIT, hal.HAL_OUT)
@@ -1248,6 +1253,18 @@ class HandlerClass:
         if self.heightOvr > 10 :self.heightOvr = 10
+    def height_ovr_encoder(self,value):
+        if (value != self.old_ovr_counts and self.extHeightOvrCountEnablePin.get()):
+            self.heightOvr += (value-self.old_ovr_counts) * self.w.thc_threshold.value()
+            if self.heightOvr < -10 :self.heightOvr = -10
+            if self.heightOvr >  10 :self.heightOvr =  10
+            self.heightOverridePin.set(self.heightOvr)
+            self.w.height_ovr_label.setText('{:.2f}'.format(self.heightOvr))
+        self.old_ovr_counts = value
@@ -1859,7 +1876,8 @@ class HandlerClass:
         self.extRunPausePin.value_changed.connect(lambda v:self.ext_run_pause(v))
         self.extHeightOvrPlusPin.value_changed.connect(lambda v:self.height_ovr_pressed(v,1))
         self.extHeightOvrMinusPin.value_changed.connect(lambda v:self.height_ovr_pressed(v,-1))
+        self.extHeightOvrCountsPin.value_changed.connect(lambda v:self.height_ovr_encoder(v))
         self.probeTestErrorPin.value_changed.connect(lambda v:self.probe_test_error(v))
     def set_axes_and_joints(self):
Time to create page: 0.795 seconds
