setup qtplasmac
- phillc54
- Thank you received: 2100
I don't have a spare for testing, if you have tested it and are happy with it then push a PR.
- fupeama
- Thank you received: 14
I tested MPG code on 7i76e with 7i73 (pendant card) with handwheel and looks fine.
I have one more question. I'm going to adjust the plasma so I can use an oxy fuel torch. I would need to manually adjust the height "z" without the probe and start burning. Scribe is similar. Uses arm delay and on delay. This could be used to preheat the material and then for the cutting itself. Do you think it's a good idea? Do you plan to add oxy fuel support to plasmac? Thanks Martin
- phillc54
Great, thanks.HI,
Edit: I forgot to mention that when you submit a PR could you also increment the version at the very top of qtplasmac_handler.py and also add the change to versions.html which is in the same directory.
I think it is worth experimenting with. I have no oxy gear so I cannot help much...I have one more question. I'm going to adjust the plasma so I can use an oxy fuel torch. I would need to manually adjust the height "z" without the probe and start burning. Scribe is similar. Uses arm delay and on delay. This could be used to preheat the material and then for the cutting itself. Do you think it's a good idea?
I did intend to a long while ago, I got some info from Tommy but I got sidetracked with other things and I probably cannot even find that now. We could certainly take a look later if there is enough interest.
- Thank you received: 7463
Do remind me, i will write it again sometime ... like not at 3AM !
- phillc54
Thanks Tommy, I seem to remember something about gas solenoids... My memory is shot.Just lost over an hour searching fro that info, no luck.
- fupeama
can I ask you to commit new PR? I added a scale for better MPG settings for overriding the Z height.
Some MPGs are too sensitive to adjust Z heigt.
Many thanks.
Martin
- phillc54
Hi Phill,
Many thanks.
Martin
I can but could you increment the version number, I pushed a .63 a couple of hours ago.
- fupeama
OK?
Martin
- fupeama
I add some more external pins for THC enable, Autovolts, Kerfcross etc.
Pleas can you check new PR and commit it?
PR:
Add external pin for THC, Auto Volts, Cut Rec move etc
#1321
thanks Martin
- phillc54
github.com/LinuxCNC/linuxcnc/pull/1321
