setup qtplasmac
- billykid
- Thank you received: 83
11 Jan 2022 20:43 - 11 Jan 2022 20:45 #231479
by billykid
Replied by billykid on topic setup qtplasmac
With the network cable, the internet and the 7i80 work together and the latency errors seem to have disappeared as well. often,
the mesa is not seen and I have to turn it off and on again to work, surely the interfaces file is done at random because before I had done it in a graphic way ... I am attaching it if someone (Rod) helps me to fix it
Last edit: 11 Jan 2022 20:45 by billykid.
- Thank you received: 4149
11 Jan 2022 23:48 #231500
Replied by rodw on topic setup qtplasmac
Is eth0 the name of the NIC? they are often different to that.
I think ip a (or ip -a) will tell you
- billykid
12 Jan 2022 08:42 #231537
by billykid
Here is the result of ip a: eth0 and eth1 seem right to me.
12 Jan 2022 08:48 #231539
Looks right.Here is the result of ip a: eth0 and eth1 seem right to me.
- billykid
12 Jan 2022 08:59 #231542
by billykid
should I start everything and turn on the mesa later or all together? because sometimes the mesa doesn't work and I have to turn it on and off to make it work.
- Thank you received: 7478
12 Jan 2022 09:00 #231543
Replied by tommylight on topic setup qtplasmac
Yup that looks OK.
Are you using WiCD by any chance ?
- billykid
12 Jan 2022 09:04 - 12 Jan 2022 09:05 #231544
by billykid
now i don't use wifi only cable. with wicd it worked one connection at a time and every now and then latency error that now seems to disappear.
MX 19
MX 19
Last edit: 12 Jan 2022 09:05 by billykid.
12 Jan 2022 09:16 #231546
Just went back over this, so
-hijacking topics/threads is not nice
-i have no clue what exactly your having issues with as you keep spoon feeding us info
Can you please sit down and write exactly what the issues are?
-ping 10.10.10.10
-latency-histogram --nobase --sbinsize 1000 --show
-uname -a
-ping 10.10.10.10
-uname -a
- billykid
12 Jan 2022 09:28 #231549
by billykid
Sorry Tom the main problem is the translator
I wanted to list the behavior with wifi and with cable. with the cable I have no latency problems and I use that. only problem with the cable is that at start up sometimes the mesa is not ready ... I have to remove the 5 volts and give them back to make it work, only this is wrong.
12 Jan 2022 12:08 #231556
ip a
ping 10.10.10.10
Do this when everything is working, and when it is not working.
Also, what 5V power supply are you using and do you have any other ?
ping 10.10.10.10
The following user(s) said Thank You: billykid
Time to create page: 0.219 seconds
