setup qtplasmac
4 years 9 months ago #231549 by billykid
Replied by billykid on topic setup qtplasmac
Sorry Tom the main problem is the translator :-) I wanted to list the behavior with wifi and with cable. with the cable I have no latency problems and I use that. only problem with the cable is that at start up sometimes the mesa is not ready ... I have to remove the 5 volts and give them back to make it work, only this is wrong.
4 years 9 months ago #231556 by tommylight
Replied by tommylight on topic setup qtplasmac
ip a
ping 10.10.10.10
Do this when everything is working, and when it is not working.
Also, what 5V power supply are you using and do you have any other ?
The following user(s) said Thank You: billykid
4 years 9 months ago #231559 by billykid
i disabled the wifi interface in the bios, tried a few starts and it always worked. if the problem recurs I will do the tests you said. the power supply is a 5 volt 5 amp dc dc converter
I think it's reliable but just in case I try another one.
it.rs-online.com/web/p/convertitori-cc-cc-isolati/0592379
4 years 9 months ago #231561 by tommylight
Yeah that looks like a really nice dc-dc converter, so we go back to chasing network issues.
4 years 9 months ago #231566 by billykid
I have the data of "ip a" when neither mesa nor network works and the other with both working. i used a usb network adapter for internet, it seems that when it is not detected not even the mesa works. I changed the usb port and for now it works ... I am attaching the 2 files thank you
4 years 9 months ago #231567 by tommylight
Start a new topic in the computers section, this has nothing to do with QtPlasmaC.
Please attach all the info you gathered.
Also when it stops working, unplug and plug back the cable to mesa board, see if that brings it back.
Time to create page: 0.396 seconds
