MonoKrom - QtPyVCP GUI for PlasmaC and Mill
  • pinder
  • pinder's Avatar Topic Author
  • Elite Member
  • Elite Member
19 Sep 2020 18:30 - 05 Oct 2020 15:21 #182773 by pinder
hello everyone.
I want to make a new gui for my PlasmaC Machine.
PlasmaC axis and gmoccapy work just fine, I just want to make an exclusive GUI. Can anyone guide me.
Moreover, other thing I want is that my system boots directly to the Plasmac, just like Pathpilot. If we want to desktop, there should be some key combination.
Pathpilot is based on linuxcnc if that can do it, linuxcnx should also.
Thanks in advance.
Update: 01/10/2020
MonoKrom is the decided name.
@KCJ is working hard in qtpyvcp.
05/10/2020
added VCP for Mill MonoKrom-Plasma & MonoKrom-Mill
You can install semi-working GUI from github
This is the result so far.
After discussions monochrome yellow is the way to go.
Last edit: 05 Oct 2020 15:21 by pinder.
The following user(s) said Thank You: TurBoss
19 Sep 2020 20:23 #182781 by tommylight
Replied by tommylight on topic qtpyvcp Gui for plasmac
Are you willing to share that GUI after you are finished?
Yes, most probably for whatever is reasonable.
How i can load plasmac run tab in Plasmac.
Just add the link to "startup applications" from the preferences menu. Or if you really want to skip everything else, use the "kiosk" mode for Linux.
  • pinder
  • Elite Member
  • Elite Member
20 Sep 2020 05:05 #182818 by pinder
Replied by pinder on topic qtpyvcp Gui for plasmac
Yes, definitely I am.
Thankyou @tommy, you are an inspiration for the community.
How can i load plasmac panels(config, run, preview) in qtpyvcp.
I will dig that up.
  • pinder
  • Elite Member
  • Elite Member
20 Sep 2020 05:12 #182819 by pinder
This is a sample of GUI
I am targeting touch screens. After working out the GUI I will also share physical control panel plans.
20 Sep 2020 07:49 #182830 by tommylight
Not that i am aware of, i think there is some work going on on QtVCP, but not on QtPyVCP , but PlasmaC works with Axis and Gmoccapy for now.
The following user(s) said Thank You: pinder
20 Sep 2020 08:02 - 20 Sep 2020 08:02 #182832 by phillc54
Replied by phillc54 on topic qtpyvcp Gui for plasmac
The PlasmaC panels are all Gladevcp panels so I doubt they would work with qtpyvcp.
I would imagine that you would need to rewrite it to fit into this environment.
Last edit: 20 Sep 2020 08:02 by phillc54.
20 Sep 2020 08:27 #182836 by rodw
Replied by rodw on topic qtpyvcp Gui for plasmac
Does Phill happen to have that on his to do list?
The following user(s) said Thank You: robertspark
20 Sep 2020 08:31 #182838 by phillc54
Not this Phill :)
20 Sep 2020 08:36 #182841 by rodw
Well, I can't hit the thank you button on that reply so I just have to say in true Aussie Spirit
Oh Bugger!
20 Sep 2020 09:17 #182846 by phillc54
I do have long term plan but that will be Qtvcp, not qtpyvcp.
Moderators: KCJ, Lcvette
Time to create page: 0.551 seconds
