Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
2 years 9 months ago #290175 by Joco
It’s been looked into, but like anything, its a case of competing priorities.
2 years 9 months ago #290382 by warwickben
i dont know if i missed this or not, or its just a issue with how i installed probe basic.
i started with a clean install of 2.9.2  and setup a axis config using a saved pncconf.
tested the axis config and machine worked like it should.
then i followed the guide to setup probe basic.
when i tried to first start it i had a conflict.   axis vs probe basic manual tool change.  just had to go and hand remove all the axis call outs( dont know how to refer to it ? axis code for tool changes) .
2 years 8 months ago #292233 by Golab
Hello.
I'm an absolute novice on the subject and I need help.
I installed Debian 12 from the website  kcjengr.github.io/probe_basic/quick_start.html
I followed all the instructions.
The installation was successful, and the Probe Basic simulation starts up.
I configured the machine in Pncconf in Axis version, and everything seems to be okay.
Then, step by step, I followed the conversion instructions mentioned above. It seems to me that I did it correctly, only changing in the ini file in the "TRAJ" section from 5 axes to 3 axes and from XYZAB to XYZ. Previously, I changed G20 to G21.
Unfortunately, the program does not start, and an error pops up.
I'll add that the card I'm using is the Mesa 7i76e.
I attach the report generated by Linuxcnc to the post.Perhaps someone will notice something?
2 years 8 months ago #292238 by tommylight
The file
moya_maszina.hal
is missing some stuff, like for example :
2 years 8 months ago #292240 by Golab
I think this entry is located in the file Moja_Maszyna.hal.
2 years 8 months ago - 2 years 8 months ago #292241 by Aciera
But the [EMCMOT] section in your ini file is empty.
[edit]
for your setup I would have expected something like this:
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1500000
Last edit: 2 years 8 months ago by Aciera.
Moderators: KCJ, Lcvette
Time to create page: 0.572 seconds
