Py3 - Probe Basic Config Conversion Doc Lcnc 2.9+
2 years 8 months ago #292430 by tommylight
You did not omit the "coolant_cannon.hal" file in the ini file, it is still looking for it.
2 years 8 months ago - 2 years 8 months ago #292936 by Golab
In the HAL section of the ini file, I commented out the file "coolant_cannon.hal".
The program still doesn't start.
Ps.I pasted an image here and some gibberish popped up. Sorry
Last edit: 2 years 8 months ago by Golab.
2 years 8 months ago #292942 by tommylight
OK, most of it is correct, the Mesa board gets set up fine, but there are errors with filename or missing file required by QtPyVCP.
Sorry, i have no experience with it.
The following user(s) said Thank You: Golab
2 years 8 months ago - 2 years 8 months ago #293099 by Golab
 I reinstalled the system (debian-12.5.0-amd64-netinst.iso).
Last time it was LinuxCNC_2.9.2-amd64hybrid.iso.Perhaps that was the cause of my failures.(mayby not)
I followed all the necessary steps provided on the Probe Basic .deb Installation instructions page, then tried to follow the instructions provided in this topic.
The program still doesn't start, but it seems I'm getting closer. Adding the line; USER_TABS_PATH = user_tabs/ to the DISPLAY section in the ini file, the interface appears along with the error message window (I'm attaching a screenshot).Unfortunately, when I press Ignore, the interface/program closes :(I'll add that GUI AXIS works. Sim PB too.
2 years 3 months ago #304492 by Chriss26
Hello folks I'm currently in the process of setting up Probe Basic.
My problem is that the emergency stop doesn't work it is always on.
When I try to reset the emergency stop, Probe Basic hangs for 5 seconds nothing happens after that. I've tried everything possible but I just can't get anywhere.
There is no external emergency stop linked
Does somebody has any idea. thank you in advance
2 years 3 months ago #304607 by Lcvette
need more information on installation, system
Moderators: KCJ, Lcvette
