- Thank you received: 4
rpi does not support the vtk used with qtpyvcp and is not supported. some have tried but i have not seen a successful implementation to date that i am aware of, if someone has done it maybe they can chime in?Hi Chris,
I heard there's been a lot of development on Probe_Basic recently and some new contributors.
Thanks for the fantastic work everyone !!!
Question; We currently have two CNC routers running Probe_Basic on Debian 10 and Mesa cards. We're trying to build a new Probe_Basic controller using a Raspberry Pi 4 and the BTT SKR v1.4 Turbo board. Do you know if the instructions above will work for that situation ?
thanks to your instructions i got Probe Basic set up.
But i have a weird problem which i don´t understand. I have a working Machine with Axis Screen and Ethercat Hardware (motion & io).
If i start this Machine i am able to jog around and the jogged distances & speeds match the movement on the machine.
In Probe basic somehow the Axis are moving far to slow also the distances are off. Seems that there is some scaling done in background?
I don´t know where i can also look.
My Axis - INI / hal
My Probe Basic - INI / hal
My Axis - INI / hal
use the config conversion document in post 1, your increments setting is wrong way to many to fit probe basic and missing the "JOG" label for continuous jogging mode.
Okay i will undo my changes in this section to your defaults![]()
PB does not scale anything beyond the on screen sliders and these are scaling via percentage against the ini configuration, if they are too slow make sure they are set to 100% on screen for both the velocity slider and jog slider. this will set both to maximum, if thise does not resolve the issue i am unsure what else it could be, perhaps a setting in the ethercat configs? but i am not current on ethercat setup, perhaps @rodw can chime in if the first fix does not resolve the issue.
Alright then i will test this next time i am on the machine
What i have already tested is the joint.0.vel-cmd output in both Machine sets
in AXIS Screen the output value at jogging the X-Axis was around 2.4
in Probe Basic the output value at jogging the same Axis was near 20
in Axis Screen the movement speed of the Machine was normal but in Probe Basic it was very slow as for scaling and moves not matching this is 100% in the ini setup and or hal. so you would need to ensure those settings are correct.
i will look at my configs again and compare my 2 hal and ini files in vs code maybe i find something
Thank you
Sven
Chris
