- Thank you received: 8
2023-12-07 16:20:11,555 - qtpyvcp.app.launcher - CRITICAL - Unhandled exception in probe_basic line 8
File "/usr/bin/probe_basic", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 228, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 208, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 56, in __init__
self.load_programmable_coolant_cannon_settings()
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 93, in load_programmable_coolant_cannon_settings
self.activate_programmable_coolant.setValue(int(INIFILE.find("COOLANT_CANNON", "ACTIVATE")) or 0)
TypeError: int() argument must be a string, a bytes-like object or a real number, not 'NoneType'
[COOLANT_CANNON]
ACTIVATE = 0
HORIZONTAL_SPINDLE_NOZZLE_DIST = 0
VERTICAL_SPINDLE_NOZZLE_DIST = 0
PC_ANGLE_OFFSET = 0
