qtvcp issues
8 years 4 days ago #119537 by cmorley
Replied by cmorley on topic qtvcp issues
I'll just remind you that you need to clear any geometry entries in the preference file from your last test, or the dialog may follow them.
8 years 4 days ago #119538 by cmorley
Well onboard does load, at least in Mint 13:
Chris M
  • auto-mation-assist
  • Platinum Member
  • Platinum Member
8 years 3 days ago #119568 by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
Nice, the keyboard looks great I will see if I can get it to show up in my stackedWidget_2 index 1 later today. Is there some thing special that needs to be done to get it to load? My stackedWidget_2 index 1 has space for 954x228 objects which I figured was large enough for a key board.
I will also try out the other changes you have made after I get done doing some button work between the gui .ui file and the handler. I will go ahead a do a pull now.
8 years 3 days ago #119569 by cmorley
I added a layout widget, then the XEmbed widget, change the command property to onboard --xid
I think i added a spacer widget to make the keyboard a bit better size.
Chris M
8 years 3 days ago #119573 by cmorley
Well it seems while the keyboard a;ways embeds..it doesn't work consistently - at least for me.
Chris M
  • Platinum Member
  • Platinum Member
8 years 3 days ago - 8 years 3 days ago #119581 by auto-mation-assist
I would think that if the keyboard does not work constantly that is a good chance that its a timing related issue. I have not had a chance to look at it.
Ran into a little problem with push button action to bring up a page when used with python cmd string and is checked in checkable.
True cmd string: INSTANCE.stackedWidget_2.setCurrentIndex(1)
False cnd string: INSTANCE.stackedWidget_2.setCurrentIndex(0)
The thought is that the button should act like a toggle button, push on, push off. But as soon as the mouse is released from pushing the button to the on state it sends the false cmd with the button indicating that it is still in the true state. Thus it sends commands improperly under this condition.
I would like to have the keyboard pop up like mdi and file editing modes are selected but have it selectable whether to do that or not via another button.
Last edit: 8 years 3 days ago by auto-mation-assist.
Time to create page: 0.206 seconds
