qtvcp issues
7 years 11 months ago #119872 by cmorley
Replied by cmorley on topic qtvcp issues
That looks great!
Looks like the button labels are changing properly now.
Jogging I would suggest using action buttons for jogging buttons.
jo_joint_pos_action and jog_joint_neg_action are for positive and negative direction (use momentary buttons) setting the joint_number to the appropriate axis number.
For jogging increment buttons:
jog_incr_action sets a global variable for current jog increment.
By setting the properties incr_imperial_number and incr_mm_number it also takes care of switching units in G20/G21 modes.
In this way the GUI is aware of your jog increments so things like status_label can be used to display the current jog increments.
You can certainly roll your own if you have some good reason to, but I would still suggest letting qtvcp know about it by using the ACTION / STATUS library.
eg.
ACTION.SET_JOG_INCR(.010)
rate = STATUS.get_jog_increment()
Noting these expect the rate to be in machine units no matter what G20/G21 mode you are in.
Chris M
7 years 11 months ago #119875 by cmorley
About Github and sample configs.
Looks to me you have forked linuxcnc on github.
checking out qt5vcp and making sure it's current - you probably already do this:
git checkout qt5vcp_py2
git pull
So then if you make a new branch based on qtvcp:
git checkout -b x1mill_branch
Then copy your UI and handler files into configs/sim/qtvcp-screens
then copy and paste the qtdefault.ini file into the same folder and rename it to x1MILL.ini
open that and change the line (heading under [DISPLAY]):
DISPLAY = qtvcp
to:
DISPLAY = x1MILL -d
The -d is for debugging mode - you can change that if you like.
Confirm that that loads and runs (Yaa a simulated config!)
Now commit those files.
cd into the configs/sim/qtvcp-screen folder and add/commit the files
git add x1MILL.ini x1MILL.ui x1MILL_handler.py
git commit
write your commit message and save the commit file.
If you have installed gitk then I like to use it to look at what I did:
simply enter 'gitk' in the terminal that is cd'd somewhere into the linuxcnc folder.
The top commit should be your the commit you entered.
If you click on the commit you can see the changes made.
ok check that pushing to the repo is gonna work ok -that depends on how you set up github:
git push --dry-run
all good then actually push:
git push
Then everyone should be able to pull your changes.
I would suggest doing all your work on that branch now - committing as you hit milestones (read that: often)
and pushing to the repo when you want to share.
Hopefully i didn't tell lies and that helps you figure out how to create a sample config.
Chris M
7 years 11 months ago #119876 by cmorley
cmorley wrote: That looks great!
eg.
Chris M
This is why it's really helpful to work with someone on a project - forces you to look at things with 'new' eyes.
I see some errors in the library that I must fix.
eg.
should require a text entry too:
ACTION.SET_JOG_INCR(.010, '.010 in')
Thanks!
Chris M
  • auto-mation-assist
  • Platinum Member
  • Platinum Member
7 years 11 months ago #119881 by auto-mation-assist
Replied by auto-mation-assist on topic qtvcp issues
Chris,
On a number of occasions you have mentioned "the preference file". The only preference file that I know about and called out in my .ini file is:
/configs/x1Mill/x1Mill_preferences (used by gmoccapy).
I believe you are talking about a preference file related to QT specific items instead. Something has a mind of its own when it comes to on screen locations.
For example in the .ini file I have:
[DISPLAY]
DISPLAY = qtvcp -d -g 1024x768+0+0 then .ui location,
It no longer goes to 0.0 on the screen since a pull in the last day or so. Comes up in the center now instead of where it was commanded to go.
For me the dialogs continue to move where they should not move to so I need to clear out the illusive preference file.
7 years 11 months ago #119883 by cmorley
The preference file in in your home folder - it is hidden so you must set your file browser to show hidden files.
It's default name is .qtvcp_screen_preferences
I haven't tested the -g option in qtvcp for some time but it has nothing to do with the preference file. (I will check it now though)
If you use the command similar to :
self.w.tooloffsetdialog._geometry_string='0 0 600 400 onwindow'
(put it in the intialized__ function)
in the handler then it will override the preference file.
Chris M
7 years 11 months ago #119885 by cmorley
Ok I think I know what the dialog placement problem is - empty preference file will trip it up....i ddin't test that :)
main screen placement with;
works for me.
Chris M
Time to create page: 0.159 seconds
