Inconsistent Error Messages
- snowgoer540
- Thank you received: 907
07 Mar 2021 03:05 #201257
by snowgoer540
I did not have that installed. I installed it and it's good to go. I think Phill is going to update the script.
Thank you for the help!
Replied by snowgoer540 on topic Inconsistent Error Messages
Do you have python-dbus.mainloop.pyqt5 installed?
- Thank you received: 7478
10 Jun 2021 23:03 #211752
Replied by tommylight on topic Inconsistent Error Messages
In another topic i did suggest having the error/warning messages in a tab in QtPlasmaC since under Linux Mint there are no popups and the messages on the lower left side dissapear very quickly and if the mouse is moved. This is implemented in ProbeBasic (the GUI, not the probe tab for Axis/Gmoccapy) so that might be a starting point.
- Thank you received: 2181
11 Jun 2021 00:15 #211757
Replied by cmorley on topic Inconsistent Error Messages
Mint should pop messages if you have the libraries installed.
I use Mint.
check the terminal for a warning about this.
I use Mint.
- snowgoer540
11 Jun 2021 00:30 #211759
by snowgoer540
When I had this problem (Mint 19.2), I don’t recall any error messages about missing dependencies (not saying there weren’t any).
The odd thing at the time was that sometimes I would get them, and sometimes I would not.
I finally gave up and converted everything to MX Linux, but I know people love Mint.
I know of one other guy having this problem on the iso distribution of lcnc, running Buster I reckon.
Not sure if any of that helps. I know it’s difficult to duplicate what you can’t replicate.
11 Jun 2021 05:20 #211772
interesting - yes intermittent problems are the worst.
11 Jun 2021 05:29 #211773
I'm sorry I had forgotten the problem and didn't reread the thread.
It seems mint 19.2 is the problem.
Sorry for the noise
Sorry for the noise
- phillc54
- Thank you received: 2100
13 Jun 2021 02:04 - 13 Jun 2021 05:22 #211909
by phillc54
Replied by phillc54 on topic Inconsistent Error Messages
Hey Chris, a few of questions about the on screen display for error messages.
Is there a pin/signal/parameter hidden away somewhere that indicates a button on the OSD has been clicked?
Is there a way to limit the number of messages on the OSD to say 5 or 3 to prevent the OSD ending up partially off screen?
Is there a way to prevent the OSD from being shown?
By "a button", I mean "Close", "Clear All", and "Show Last Five"?
Edit: I have attached a diff that gives an example of what I would like to achieve.
Last edit: 13 Jun 2021 05:22 by phillc54. Reason: add attachment
13 Jun 2021 10:42 #211929
1) no but it's possible.
2) no there is no information about how many messages are currently showing or how big the message box is. I can dig in a bit to see if that info is available somehow.
3) you can disable notify messages in the screenoptions or do you mean temporarily?
- phillc54
13 Jun 2021 12:54 #211932
by phillc54
Thanks Chris.
1. Yeah, there is a dodgy way in the diff I posted
2. I saw it was hard coded in notify.py
3. Permanent with a user selection
13 Jun 2021 23:57 #211978
3)
-you can disable notify using the preference file.
- you can override that in the handler file: self.w.screen_options.setProperty('notify_option',False)
You will lose the error message going to the status bar too - if that matters.
Time to create page: 0.975 seconds
