Inconsistent Error Messages
- Thank you received: 2181
16 Jun 2021 05:44 #212175
Replied by cmorley on topic Inconsistent Error Messages
i'll look at your suggested code as soon as i can. - working a lot lately.
thanks
thanks
23 Jun 2021 04:32 #212717
i was thinking it might be useful to include in the STATUS message the type and state of the button returned.
What does osd stand for? something system dialog?
'system_notify_button_pressed' might be better?
Still working steady so didn;t get any father then that....
def yesClicked(self, n, action, callback):
callback(True)
STATUS.emit('error_osd_button_pressed', 'YesNo",True)
def noClicked(self, n, action, callback):
callback(False)
STATUS.emit('error_osd_button_pressed', 'YesNo',False)What does osd stand for? something system dialog?
- phillc54
- Thank you received: 2100
23 Jun 2021 05:16 - 23 Jun 2021 11:16 #212719
by phillc54
Replied by phillc54 on topic Inconsistent Error Messages
Yes, that would probably be more flexible.
On Screen Display, for want of a better description, which your one is...
Edit: I had a bit of a play with putting the maximum messages in the prefs file, the attached diff is what I came up with:
Last edit: 23 Jun 2021 11:16 by phillc54.
26 Jun 2021 04:42 #212943
I pushed your work to master.
adjusted the names a bit - let me know if it's not what you wanted.
Chris
Chris
- phillc54
26 Jun 2021 06:28 #212948
by phillc54
Perfect Chris, thank you.
The change in istat.py is not needed now with having notify_max_msgs in the prefs file.
27 Jun 2021 00:33 #212989
ok thanks i'll remove it.
Time to create page: 0.310 seconds
