Error in tool_offsetview.py
3 years 9 months ago - 3 years 9 months ago #261383 by hottabich
Replied by hottabich on topic Error in tool_offsetview.py
Hello! Can you share files panels? Thank you!
Last edit: 3 years 9 months ago by hottabich.
3 years 9 months ago #261402 by cmorley
Replied by cmorley on topic Error in tool_offsetview.py
OK,
little help please.  I have looked through all the docs I can find.....
where and how can I specify the size and location of each screen?
in the .ini ?
in the .pref ?
thanks in advance....
I haven't tried these in a while but look here:
linuxcnc.org/docs/2.9/html/gui/qtvcp.html#_ini_settings
Also the panel you made can have it's size set in the designer editor.
3 years 9 months ago - 3 years 9 months ago #261747 by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
hello ChrisAfter the last addition of tool buttons, the DRO layout broke a bit. I made the appropriate corrections, and I'm sending you the corrected theme file as well.I also found one problem with the "DEFAULT_ANGULAR_VELOCITY" option from the .ini file, this option does not work. The slider of the A axis should be set to the appropriate position after starting qtdragon and it is always set the same, regardless of the set value.And above all, what progress with the validator, because it is quite a serious problem for some users?Marek
Last edit: 3 years 9 months ago by MarkoPolo.
3 years 9 months ago #261751 by cmorley
The validator changes to qtdragon were done quite some time ago.
Maybe I missed some needed changes for other widgets?
I'll update the theme and ui, thank you.
I'll look at that default angular setting.
3 years 9 months ago #261753 by MarkoPolo
Indeed, now I see it running in the main qtdragon window, thanks.
Not working yet in "probe" and in "utils" tab in "facing", "bold hole circle" and "ngcgui"
3 years 9 months ago #261768 by cmorley
Ok angular jog rate problem fixed.
Theme updated (thanks)
DRO layout fixed (thanks)
basic broke and facing should accept decimals now - please test and get back to me.
I'll work on the rest after you confirm all is good.
all just pushed to 2.9 and master ...
Time to create page: 0.528 seconds
