Error in tool_offsetview.py
3 years 9 months ago #262332 by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
After the next update it's ok
3 years 9 months ago - 3 years 9 months ago #262914 by MarkoPolo
I am uploading the updated and modified theme file.
There is also a minor bug in qtdragon , the "pause spindle" button should be disabled when in "auto" mode.
In qtdragon_hd this button works properly.
Marek
Last edit: 3 years 9 months ago by MarkoPolo.
3 years 9 months ago #262977 by cmorley
Replied by cmorley on topic Error in tool_offsetview.py
Thank you I pushed these changes!
The following user(s) said Thank You: Roguish
3 years 5 months ago #270435 by MarkoPolo
Long time no changes to qtdragon so I have two minor things.Minor fixes to the brushed_metal_color theme, and a problem with displaying the diameter of the tool if the tool is number 0.I don't know if it should be numbered from zero, but I guess so, since you can choose such a number. The problem is that the diameter fields show 0 instead of the correct tool value as in the screenshot.
3 years 5 months ago #270536 by cmorley
Tool 0 is usually used for no-tool-in-spindle so I bet the code assumes that.
Random and non-random tool changers don't agree on what tool 0 can do.
3 years 5 months ago #270539 by rodw
Replied by rodw on topic Error in tool_offsetview.py
The diameter is being set in the graphic here with the latest qtd
My tool start at 1
Time to create page: 0.150 seconds
