Error in tool_offsetview.py
3 years 5 months ago #271365 by cmorley
Replied by cmorley on topic Error in tool_offsetview.py
status bar test is recorded in the log, so can always be looked up.
I can unlock the log and settings in auto mode.
I don't see too much in settings that could create a problem.
Both are one word changes so lets test and see...
The following user(s) said Thank You: Roguish
3 years 5 months ago - 3 years 5 months ago #271813 by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
There was some free space on the bottom bar of the bar, so I added a 'machine' status, if it's useful, you can make changes.
Someone on the forum suggested replacing the probe ball with a ruby one, so I replaced all the balls with ruby ones.
Roguish. You want to achieve high measurement accuracy, I don't know if changing the ball to a ruby one will help but you can try :)
Last edit: 3 years 5 months ago by MarkoPolo.
3 years 5 months ago #271831 by cmorley
I agree the red looks nicer - but I have just changed location of the ball in most of the images.
I also like the status label in the bar,
3 years 5 months ago #271846 by Roguish
Replied by Roguish on topic Error in tool_offsetview.py
Thanks for the work.....
The material of one's spherical probe tip doesn't really matter. It's the pure accuracy of the sphere diameter. Most all are good enough for simple day to day use. Guess if it's used on a super high end CMM for highly critical dimensioned parts it would make a difference. Then the old rule of $$$ == quality is true.
In regard to the images and layouts, etc, of the probing routines, consistency is critical.
3 years 5 months ago #271902 by rodw
Replied by rodw on topic Error in tool_offsetview.py
Chris might disagree but the corner balls need to be in the white area. Misleading where they are.
3 years 5 months ago #271939 by Roguish
If the cute red or purple balls are the 'starting' point, they should definitely be where they belong, per the probing code......
Once again, probes are expensive. It's not fun to have to test every routine before actually using them. And testing with a finger poised on the E-stop button.....
The images are a part of the docs. And remember, a picture is worth lots of words.....
