- Thank you received: 2181
Error in tool_offsetview.py
1 year 5 months ago #328564
Replied by cmorley on topic Error in tool_offsetview.py
I did push some work to fix an error I found.
The following user(s) said Thank You: MarkoPolo
- MarkoPolo
- Thank you received: 90
1 year 5 months ago #328586
by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
It's almost good.
Setting the style in the qtdragon file is quite sufficient.
Restoring settings from the file works well, but only if they are integers.
If it's a floating-point number, then an error appears as in the screenshot.
Another problem (request, proposal) is the "RadioButton" element. It works like a switch and in some macros this is the desired behavior, but in others it is not.
If I want more items to check a logical condition, then there is a problem. That's why a new "CheckBox" element would be useful.
1 year 5 months ago #328593
Ok fixed floating point problem.
added new default commands:
for a radio button (with exclusive behavior)
radiotrue
radiofalse
for a checkbox (independent):
checktrue
checkfalse
true and false now will show a checkable pushbutton
Chris
radiotrue
radiofalse
checktrue
checkfalse
Chris
- MarkoPolo
1 year 5 months ago #328604
by MarkoPolo
Great.
Everything works fine, that's what I wanted. Thanks a lot.
It would be good to update the documentation, because old ngc files with "MACRODEFAULTS=true,false" settings will stop working for some users after updating "MacroTab".
Marek
Marek
1 year 5 months ago #328611
I did update the docs but..
Maybe I should set true/false to be radio buttons too and add buttontrue/false.
- MarkoPolo
1 year 5 months ago #328614
by MarkoPolo
Maybe leave it as it is now, but add so that radioButton also works with true/false string for backward compatibility ?
Time to create page: 0.717 seconds
