Error in tool_offsetview.py
2 years 4 weeks ago #311266 by cmorley
Replied by cmorley on topic Error in tool_offsetview.py
Hi Cmorley
I don't know if you plan to implement the layout in qtdrahon_hd
the same as in qtdragon. If so, I have a modified file, ready to use.
Pushed to master.
Thank you!
1 year 11 months ago - 1 year 11 months ago #313633 by MarkoPolo
Replied by MarkoPolo on topic Error in tool_offsetview.py
Hi ChrisI
Have some fixes qtdragon .
1. Fixed wrong button size in qtdragon_hd g54
2. Fixed button qss file for qtdragon
3. The "systemtoolbutton" button should be removed from the "button_response_list" list in the support file, because in auto mode during work, it is not active.
What is the function of the red frame in the gcode field?
If I click in MDI and a red frame appears, it is not possible toremove it later.
Last edit: 1 year 11 months ago by MarkoPolo.
1 year 11 months ago #313642 by cmorley
pushed.
Thank you for your continued fixes of my misses :)
The following user(s) said Thank You: tommylight, MarkoPolo
1 year 11 months ago #313695 by cmorley
Oh the red highlight was for cycle start selection.
Ie in MDI mode cyclestart would run the MDI command, in Auto run the program.
It's code not ready yet, I just forgot to turn it off.
1 year 11 months ago #315063 by MarkoPolo
Hi Chris
In qtdragon the feedrate override value is displayed fine if only xyz axes are working, but if a rotary axis is added to it the value becomes useless because the angular values ​​of the rotary axis are added to the linear values.
I think the angular values ​​should be removed from "feedrate override".
It would be possible to calculate the linear speeds of the workpiece, but you would have to take into account the distance of the tool tip from the rotary axis, and the rotational speed of the axis. It gets even more complicated with two rotary axes.
Any ideas on how to do this?
Another minor thing is that the linuxcnc logo is not displayed in "setup"
it is displayed only after pressing "local files" and after pressing the return arrow.
1 year 11 months ago #315276 by cmorley
The feedrate comes straight from the motion controller and is always multiplied by 60 for minutes.
I'll have to see what AXIS does in this case as it's not obvious how to decern what the feedrate units are at any one moment.
Yes I noticed the logo problem then forgot about it :)
I'll see if I can figure it out.
Time to create page: 0.180 seconds
