- Thank you received: 115
Thanks Jim.BTW, the start point is indicated by the purple dots and the green targets are where the probe tip will be after probing.
- is there a big advantage in using G38.4 as opposed to setting the retract distance small, like 1 mm? Should it be optional?
Jim
Yes, on initial probe contact you immediately probe away with G38.4. You can do this super slow as its ony moving a 0.2mm or so.But the other advantage I see is that there is no chance the probe going the wrong way which I often experienced with the current algorithm (whether that was due to a user error or a bug). And yes if you read the docs G38.4 triggers on a falling edge. Forget the time savings and think about the accuracy. Also, there is no need to define how far to back off so there are fewer user fields. You can do some tests with the MDI. The results will be different but I thnk the 2 step probing has to be more accurate.So are you saying that with G38.4 there's no need to retract after the first contact and then reprobe at a slower speed? If so, I can see how that would speed things up although the savings in code would be insignificant. I assume then that linuxcnc knows that when it's doing a G38.4 MDI command, it should trigger on the falling edge of motion.probe-input?
