qtdragon - probing issues
3 years 5 months ago #271433 by cmorley
Replied by cmorley on topic qtdragon - probing issues
As for calibration, qtdragon VersaProbe does not have a routine for that. Probe Basic does, but I'm not sure how it operates, or if it is correct or not. I have done some searching for calibration routines and have found a few. So far they are primarily accounting for off-centerness.
Wish I had one of those super good Renishaws.
I looked at the code for calibration and I don't really get the intent.
The hole calibration does a regular X and Y probe, then does it again with the calculated center.
So far so good.
Then it calculates the X or Y or the average of both based on the difference from the calibration diameter hint (reported as delta in status).
Somehow calibration offset is used in that calculation. Are you to put the 'delta' into the calibration offset to zero out the error?
But it doesn't seem to actually use any calibration offset when doing regular probing.
Maybe it never got finished.
The following user(s) said Thank You: Roguish
3 years 5 months ago #271436 by rodw
Replied by rodw on topic qtdragon - probing issues
The calibration seems OK. I probed a metric 123 block (50mm x 75mm)
First probe
Second probe from exact centre
It seems you need to probe twice to centre the probe first. But the delta is close to the difference from the X & Y widths.
Looking at the second probe, the measurements are consistent but out by about 0.2mm. I wonder if this is the latching distance/switch hysteresis? It would be intresting to see it with G38.4 becasue I seem to remember it was about 0.2mm difference.
3 years 5 months ago #271437 by rodw
The inside corner probinfg is still worng. See video
photos.app.goo.gl/CtHjZJhMTHLYu8Zx8
Based on the initial move on start.  the probe should be situated near the corner but out a few mm from the corner towards the front eg x  -10, Y -10
I did run it from the outside of the left edge but it almost seemed like it as confusing the X direction with the Y direction.
3 years 5 months ago - 3 years 5 months ago #271458 by Roguish
Replied by Roguish on topic qtdragon - probing issues
Chris, I'm not completely sure yet what a calibration routine does. i'm looking at several that I have found. reading through them and maybe trying them out. the routine in Probe Basic may not be finished, or actually function correctly. guess we're debugging....again. better late than never.
I finally got my inexpensive probe working. Interestingly it looks identical to Rodw's in his pictures.....
So i'll be able to check on some of what I mentioned previously.
I also figured out how to see underscores in geany editor when looking at code..... really helps.
OK,  did some testing.  using the newer probe with a 2mm ball, the bearing bore ID is again measured at about 0.005in too big.  that's with a debounce time of either 2 or 5.  that's using qtdragon and versa.
more testing..  in an ncggui file, probe_hole6.ncg, which is based on cradek's p-hole, and works well, I changed the 'slow probes' to 38.4.
doesn't really work.  when it reaches the first 38.4 line it touches the bearing id and just stops.....  not sure what's happening.
Attached that file here..
Rodw, could you share a working 38.4 routine so I can see how you use it correctly?    thanks.
Last edit: 3 years 5 months ago by Roguish.
3 years 5 months ago #271465 by rodw
Rougish, I shared a Z probe with 38.4 earlier in this thread.
forum.linuxcnc.org/qtvcp/48995-qtdragon-...ssues?start=0#270612
3 years 5 months ago - 3 years 5 months ago #271478 by Roguish
rodw, thanks.   I modified the probe_hole6.ncg  (attached here) to include a g38.4 (reverse probe) following the forward slow probe.\
after each touch, I included a debug statement so it'd write out to status the data of both probes.
interesting.  all 4 probes, +y,-y,+x,-x, show about 0.004 inch difference.......that's significant.
see the file and pictures.
and it's a 30mm ID bearing
the file is set to be used in ncggui, even in qtdragon.  very handy.
. and here's the regular VersaProbe ID.
Time to create page: 0.579 seconds
