qtdragon - probing issues
3 years 5 months ago #271268 by rodw
Replied by rodw on topic qtdragon - probing issues
Chris, thanks a lot for this! very nice work... Surely we have the bugs pretty well squashed now!
Did you update the type on the external offsets too (from another thread)?
3 years 5 months ago - 3 years 5 months ago #271269 by cmorley
Replied by cmorley on topic qtdragon - probing issues
Yes fixed up the external offsets stuff too.
Surely there will be some more little things along the way.
Thanks for testing and the feedback.
Last edit: 3 years 5 months ago by cmorley.
3 years 5 months ago #271287 by cmorley
If you are asking does it automatically set g20/g21 based on machine units before probing.
I don't think it does - which does seem a bad idea.
Which behaviour do you think is a bad idea? It isn't entirely clear from the way you wrote this.
I just pushed code that uses m70/72 to record/reset the motion modes before/after probing.
Seems to work fine - though I haven't tested it much.
The following user(s) said Thank You: Roguish
3 years 5 months ago #271289 by Roguish
Replied by Roguish on topic qtdragon - probing issues
and it's Saturday morning, the 13th, and the changes are already in Seb's debs.
I will update my little mill and check 'en out.
thanks
3 years 5 months ago - 3 years 5 months ago #271294 by Roguish
Chris,
well, updated.  testing
a couple of small things.
for the 'Outside Boss'  (center pick on the Outside page)  the X Neg and X Pos results are backwards, as are the Y Neg and Ypos.
I think the assignments in probe_routine.py (line 658, etc) are backwards.  see the image attached.
also the move from the -x probe completion over to the +x probe is too big.
        # move X+ 2 * (edge_length + xy_clearance)
        aa = 2 * (self.data_side_edge_length + self.data_xy_clearance)
        s = """G91
        G1 F%s X%f
aa = 2*(1.5 +.3) ==3.6
it should be the -x radius just determined (xpres) + edge_length + xy_clearance
aa= 1.2174 + 1.5 +.3 == 3.0174
remember going out it moved (edge_length + xy clearance) = 1.5 +.3 = 1.8
so essentially ya just go back to the center and then out the same as the first out.
and the same goes for the Y probing.
Just my opinion.
The inside-pocket works fine.....
Last edit: 3 years 5 months ago by Roguish. Reason: clarification
3 years 5 months ago #271302 by cmorley
Thanks for testing.
Sounds like the similar problem with hole probing.
maybe this (have to account for latch return distance that is already moved:
(2 *self.data_side_edge_length) + latch_return + self.data_xy_clearance)
I'll look at those result calculations.
The following user(s) said Thank You: Roguish, rodw
Time to create page: 0.457 seconds
