qtvismach, a axis toolpath
2 years 7 months ago #295584 by MarkoPolo
Replied by MarkoPolo on topic qtvismach, a axis toolpath
I made a small modification to the code and now it works properly.
class Color(Collection):     def __init__(self, color, parts):         self.color = color         Collection.__init__(self, parts)     def apply(self):         GL.glPushAttrib(GL.GL_LIGHTING_BIT)         GL.glMaterialfv(GL.GL_FRONT_AND_BACK, GL.GL_AMBIENT_AND_DIFFUSE, self.color)         GL.glEnable(GL.GL_BLEND)         GL.glBlendFunc(GL.GL_SRC_ALPHA, GL.GL_ONE_MINUS_SRC_ALPHA)     def unapply(self):         GL.glPopAttrib()         GL.glDisable(GL.GL_BLEND)
I was hoping that the toolpath would be visible inside the solid, but this is not the case...
2 years 7 months ago #295585 by Aciera
Replied by Aciera on topic qtvismach, a axis toolpath
Interesting, the tool seems to be cut off too.
2 years 7 months ago - 2 years 7 months ago #295588 by Aciera
May have something to do with 'depth testing' as seen in this image where some of the background scene is not visible through the red tinted glass:
The above image comes from this article which may be useful:
drennonowereve.blogspot.com/2022/03/how-...color-in-opengl.html
[edit]
Just noticed the spelling in the article is a tad strange.
Last edit: 2 years 7 months ago by Aciera.
2 years 7 months ago #295594 by MarkoPolo
I just used this article today.
I positioned the two pieces for the test behind the workpiece and only the actual head and countertop are visible.
I don't know much about opengl, I guess it can be configured somehow...
2 years 7 months ago #295712 by cmorley
Replied by cmorley on topic qtvismach, a axis toolpath
Maybe the order of the parts can do it.
I see you can see the base and chuck through the material but not the column or other chuck.
probably there is a opengl command to directly set Zdepth but like you i know just enough to get it to mostly work :)
2 years 7 months ago #295793 by MarkoPolo
I will leave the topic of transparency for later, I have an idea how to solve it differently.
Please tell me how to easily read the x and y movement values from the "setup/properties" tab? I need these values to automatically generate the dimensions of the workpiece in the A-axis holder.
The second problem is the disappearing tool path in qtvismach. The same thing happens as in the preview window in qtdragon. A longer toolpath history is needed, or it doesn't disappear at all.
Time to create page: 1.712 seconds
