- Thank you received: 2181
qtvismach, a axis toolpath
1 year 10 months ago #316219
Replied by cmorley on topic qtvismach, a axis toolpath
I pushed HALColorRGB and HALColorFlip functions to master.
I added them to the docs too.
The following user(s) said Thank You: tommylight, MarkoPolo
- MarkoPolo
- Thank you received: 90
1 year 10 months ago #316222
by MarkoPolo
Replied by MarkoPolo on topic qtvismach, a axis toolpath
The improved color control is nice, but I haven't been able to get the material resizing to work yet.
1 year 10 months ago #316229
Have you looked at HalToolCylinder and HalToolTriangle ?
These change the shape of an object.
Can you post the material object building code?
- MarkoPolo
1 year 10 months ago #316239
by MarkoPolo
length = hal.get_value("hor_pos")
length = (float(length) + 115)
mat = Box(60, -30, -30, length, 30, 30)
mat = Color([0.4, 0.6, 0.2, 0.4],[mat])
mat = Rotate([mat],0,45,0,0)
mat = Translate([mat],0,0,0)
mat = Color([1, 1, 0, 1],[mat])
This is how I build a material element mounted in a lathe.
For now, only the material length is determined automatically, depending on the position of the lathe tailstock.
After the first simulation run, the material dimensions are drawn correctly. The problem is with rebuilding the dimension after running another ngc file with different dimensions.
I tried using HalToolCylinder and HalToolTriangle in various ways, but I must be doing something wrong
1 year 10 months ago #316303
If you create a component (called comp, with a float pin named length) in your script, you can use this for the box:
Box(comp, 60, -30, -30, 'length', 30, 30)
or with no component in the script this should work:
Box(60, -30, -30, 'comp_name.length', 30, 30)
All the other entries can use a string to force evaluation of a HAL pin too.
Chris
Chris
The following user(s) said Thank You: MarkoPolo
- MarkoPolo
1 year 10 months ago #316331
by MarkoPolo
Perfect, it works this way. thanks
By the way, I propose a small change in qt_vaismach.py
in the zooIn and zoomout functions add and subtract the value of self.near.
Now, with a big zoom, you have to really turn the mouse wheel to fully zoom in and then zoom out.
After such a change, it is much more pleasant, more linear operation.
Such a correction would also be useful in the main preview window, but I haven't found a solution for this..
Time to create page: 0.238 seconds
