qtvismach, a axis toolpath
2 years 7 months ago #295486 by cmorley
Replied by cmorley on topic qtvismach, a axis toolpath
Could be an opengui issue - all linuxcnc's opengl code uses ancient code libraries.
try this - it sets everything half alpha:
    def apply(self):         GL.glPushAttrib(GL.GL_LIGHTING_BIT)         GL.glMaterialfv(GL.GL_FRONT_AND_BACK, GL.GL_AMBIENT_AND_DIFFUSE, self.color)         GL.glEnable(GL.GL_BLEND)         GL.glBlendColor(0, 0, 0, .5)  # rgba
If it doesn't work then I would guess openGl problem.
Tk doesn't support alpha color either (it's why the qt version didn't)
The following user(s) said Thank You: MarkoPolo
2 years 7 months ago #295494 by Aciera
Replied by Aciera on topic qtvismach, a axis toolpath
In this video you can see that the tool path rotates around the C axis, so I think it can be done.
Yes, I thought you wanted a straight line to wrap around a cylinder (ie a synchronized AX move to be shown as a helix).
What you want is quite standard, you just need to attach 'work' to your rotary table.
This is an example from '/src/hal/user_comps/vismach/xyzac-trt-gui.py'
work = Capture() ctable = Collection([          work,          CylinderZ(-18, 50, 0, 50),          # cross          Color([1,1,1,0], [CylinderX(-50,1,50,1)]),          Color([1,1,1,0], [CylinderY(-50,1,50,1)]),          # lump on one side          Color([1,1,1,0], [Box(42, -4, -20, 51, 4, 5)])          ]) ctable = HalRotate([ctable],c,"rotate-c",1,0,0,1)
Examples can be found in all the vismach models with work side rotation (eg xyzac-trt-gui.py, xyzbc-trt-gui-py, xyzab-tdr-gui-py)
2 years 7 months ago - 2 years 7 months ago #295495 by MarkoPolo
Replied by MarkoPolo on topic qtvismach, a axis toolpath
it doesn't work with this code either. I've also tried entering a static value there before, but why does it work for you?
I tried on different systems, without success.
edition
I just noticed the reply.
Thanks Aciera for the code, I will try to use it.
I'll let you know if it works
Last edit: 2 years 7 months ago by MarkoPolo.
2 years 7 months ago #295497 by Aciera
As for open glTransparency:
As cmorley said, the alpha channel is broken and you have to use 'BLEND' and affiliated functions. I find it terribly confusing and I usually end having it where I did not want it.
To check if it works on your system you could just start the 'axis' simulation config and home the machine, Then look at the tool cone (which should be transparent):
I know it's not in vismach or qt but it's all opengl in the background:
2 years 7 months ago #295529 by MarkoPolo
Thanks a lot Aciera, this code example and xyzac-trt-gui.py simulation file helped me a lot.
Now it works the way I wanted.
I would also like to achieve transparency.
After basing the axis, the cone is filled with color, without transparency.
Where would I use "BLEND"?
2 years 7 months ago #295553 by cmorley
blend is the code that I added to primitives.py
Time to create page: 3.359 seconds
