qtvismach, a axis toolpath
1 year 10 months ago #317127 by cmorley
Replied by cmorley on topic qtvismach, a axis toolpath
A little more difficult, as vismach doesn't know anything about the type of move, only that it has moved. I'll experiment a bit.
It sure seems useful if vismach and the normal plotter could be combined.
1 year 10 months ago #317133 by MarkoPolo
Replied by MarkoPolo on topic qtvismach, a axis toolpath
I tried in qt_vismach.py ​​in the same way as in the screenshot, but then the color of the entire generated path changes depending on the type of movement.
Maybe draw separate paths for each color, then it will be easier to turn off the selected path?
1 year 10 months ago #317168 by cmorley
I think we would have to add the motion color into the plot point.
(qt_mismach.py line 287 ish)
        # wx, wy, wz are the values to use for backplot         # so we save them in a buffer         if len(self.plotdata) == self.plotlen:             del self.plotdata[:self.plotlen // 10]         point = [wx, wy, wz]         if not self.plotdata or point != self.plotdata[-1]:             self.plotdata.append(point)
1 year 10 months ago #317646 by MarkoPolo
I have tried various ways to use this code, but so far no results..
1 year 10 months ago #317648 by cmorley
I should have explained more.
This adds a plot point. We would need to change it to also add color.
point = [wx, wy, wz,color]
or maybe better:
self.plotdata.append([point, color])
then later in the file:
#GL.glColor3f(1.0, 0.5, 0.5)
GL.glBegin(GL.GL_LINE_STRIP)
for p,c in self.plotdata:
GL.glColor3f(*c)
GL.glVertex3f(*p)
GL.glEnd()
a few other initialization and clearing details to follow up. but that might work.
1 year 10 months ago #317656 by cmorley
Ok I pushed some work on this.
vismach_mill_xyz should show case it.
in your vismach script you need to add:
on top:
from qtvcp.core import Status STATUS = Status()
and in the Window class:
        STATUS.connect('motion-type-changed', lambda w, data: v.choosePlotColor(data))         # uncomment to change feed color and to see all colors         #v.setColorsAttribute('FEED',(0,1,0))         #print(v.colors)
The following user(s) said Thank You: tommylight, MarkoPolo
Time to create page: 0.356 seconds
