- Other Stuff
- Show Your Stuff
- 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
- phillc54
- Thank you received: 2100
16 Sep 2020 11:01 #182429
by phillc54
Replied by phillc54 on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
You may have to wake him up now he has the new bub.Life has a nasty habit of getting in the way....
Leme go poke at TheFabricator for a bit....
Hmm how do you go about pricing ?
- Thank you received: 7465
16 Sep 2020 11:16 #182430
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Noooo, i do not have bubs but i barely got 4 hours of sleep !
- machinedude
- Thank you received: 312
16 Sep 2020 12:04 #182432
by machinedude
Replied by machinedude on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
tom things kinda suck everywhere at the moment. things have been slow as hell at my work so it's everywhere i think.
China pricing Fu@k's us all on most things. the only thing worth while is a niche market but they come and go so finding them is not always easy but it is possible.
i was kinda depressed the last time i bought stuff on line. i honestly stuck to american companies hoping to see stuff made here but even the top brand stuff is made in china? not sure how things ended up so one sided? i think the large companies sold there souls to China just to pad their bottom line so they could get richer.
16 Sep 2020 12:06 #182433
As promised, here are some more videos of the T2030 and of the round tube cutter i have built for them a few years back plus the retrofitted chinese CNC to LinuxCNC and oxy/acetylene.
Enjoy.
Enjoy.
The following user(s) said Thank You: phillc54, my1987toyota
16 Sep 2020 14:48 #182442
I never get depressed, i get angry and very angry !i was kinda depressed the last time i bought stuff on line.
- Kiddekanin
28 Sep 2020 12:28 #184158
by Kiddekanin
Replied by Kiddekanin on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Hi Tommy
Can you shed a light on how you wired the THC300 inside the cebora ?
I have an old migatronic PDX85 and also got the schematics for it. but I can not quite figure out where to put the thc300 in order for the HF start not to fry it!!. It might be there right in plane sight ( but im mostly a mechanical guy - so electical seems to be my archillies) so I was hoping that you could guide me in the right direction?
Regards.
Regards.
- pinder
- Thank you received: 128
28 Sep 2020 15:18 #184177
by pinder
Replied by pinder on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
hey Tom,
Just a few questions, I think you should have faced, but I will have to read the whole thread.
1) How are the belts? better than rack?
2) What you think about float switch?
3) Should the side plate not be a single piece
or light wwight is forgiving?
28 Sep 2020 18:13 #184192
Yes of course, i still have it here so i can take some detailed pictures.Can you shed a light on how you wired the THC300 inside the cebora ?
28 Sep 2020 18:22 - 28 Sep 2020 21:14 #184195
For short distances they are much better than the rack and pinion, silent and no vibrations. 15mm wide GTD3 has proven very nice for 3.3 meters of length on the big machine, but the gantry has to be very light, in my case 23KG gantry with GTD3 belts on each side is OK.1) How are the belts? better than rack?
I always used and still use float switches, make them very sensitive so they require roughly 2KG of upward force to trigger, and they never fail. I do not use Ohmic sensing as most of my machines are to be used by other users, so i can not afford having issues with it.2) What you think about float switch?
If you mean the side plates with logos cut into them, they do not carry anything structural or any weight, so it does not matter much, they just keep the legs from twisting.3) Should the side plate not be a single piece
Last edit: 28 Sep 2020 21:14 by tommylight. Reason: typo
- pinder
29 Sep 2020 03:00 #184237
by pinder
How a 3mm sheet would work?
No I was talking about Belt drive system.
- Other Stuff
- Show Your Stuff
Time to create page: 0.521 seconds
