- Other Stuff
- Show Your Stuff
- 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
- Topic Author
- Thank you received: 5918
29 Sep 2020 10:12 #184263
Replied by tommylight on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Now i am really lost!
The belt drive system is mounted on 10mm thick aluminium plates, same for the idler bearings.
29 Sep 2020 10:24 #184264
by pinder
Nice builds.
I'll definately use belts on the gantry.
Replied by pinder on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
leave itNow i am really lost!
Nice builds.
- Topic Author
29 Sep 2020 11:00 #184271
Can you please point me in the right direction ?
- Kiddekanin
- Thank you received: 3
29 Sep 2020 12:08 #184280
by Kiddekanin
- Topic Author
29 Sep 2020 12:33 #184282
That is exactly where the THCAD should be connected, the red on the left side of the schematics.
What THC are you using ?
THCAD 300 can be wired at those two points although in the manual it explicitly says not to use it with HV start plasma, but i am using it with HF/HV plasma with no issues at all, wired at the same spots as you have marked on the left with red.
For THCAD 10 you would add a 1MOhm resistor to EACH of the wires, so two resistors in total.
- Kiddekanin
30 Sep 2020 05:05 #184350
by Kiddekanin
Replied by Kiddekanin on topic 2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
Im planning to use the THCAD300 (hence I do not have eny voltage devider and did not want to fiddle with that part)
And if it cooks, then I might have to try the THCAD10V and make a voltage devider as you describe, with the 1MOhm resistors at both leads.
Thank you weary much for the input, I can now move forward in my projekt
- Kiddekanin
30 Sep 2020 08:01 #184363
by Kiddekanin
Is there a reason why you used the 300v and not the 5v or 10v with additional voltage devider for the cebora?
- Topic Author
30 Sep 2020 18:13 #184401
It is just easier for me to use the 300.
The following user(s) said Thank You: Kiddekanin
- Topic Author
04 Oct 2020 16:22 #184838
Sorry for the lack of updates, but busy trying to start a new business (or several of them), so gathering stuff and people, fixing some other stuff, buying some stuff, etc etc.
Also my brother had his appendix removed, luckily it went well so he is recovering fine, as we as a family have some bad issues with full anaesthesia that made it very hard for us to come out of it. I did say "made it" as last two operations of my siblings went very well so something must be changing, not sure what and not sure i want to know as long as it is better.
Will do more updates when i have something worth posting.
Thank you all.
Thank you all.
The following user(s) said Thank You: thefabricator03, pinder
- Topic Author
23 Oct 2020 21:19 #187026
The following user(s) said Thank You: phillc54, thefabricator03, shpatb, snowgoer540, my1987toyota, pinder
- Other Stuff
- Show Your Stuff
Time to create page: 0.457 seconds
