2+2+3 More Plasma builds, double the joy ! 3X2M and 2.5X1.5M cnc plasma build.
  • tommylight's Avatar Topic Author
  • Moderator
  • Moderator
09 May 2020 23:56 #167193 by tommylight
Looks awesome tommy, BUt where is your beloved LAms on the Z axis. Any reason you did not use one?
Oh yes there is, i have no more ! As usual i ordered them through a friend as he needed some also, and the bastard ordered only his ! Now when i go to install everything for him, i have a feeling some are going to mysteriously disappear ! :) Nahhhh, just kidding, he just forgot as he is spaced out most of the time, or "slow" as some call that phenomena.
Unfortunately, this is dragging on so maybe i get some more of them before i finish this one. I did put a Leadshine 742 in it, and it works nicely, but it is no Lam Tech.
  • Moderator
  • Moderator
09 May 2020 23:57 #167194 by tommylight
BTW, Phill, if you watch this video, see why i need a faster retraction ? It lasts for ages like this, and the machine can do sooooo much ! :)
  • Moderator
  • Moderator
11 May 2020 11:50 #167357 by tommylight
Here is the "casually hanging on the gantry" video, at 9.6m/m.
The following user(s) said Thank You: phillc54, Clive S, rodw, CNCFred, jay1st
11 May 2020 12:08 #167359 by tecno
Time to setup a chair on the gantry for closer inspections ;)
  • Moderator
  • Moderator
11 May 2020 12:30 #167362 by tommylight
LOL, chairs are busy holding stuff. I never sit while working, ever.
  • Moderator
  • Moderator
13 May 2020 16:54 #167665 by tommylight
Here are some close ups of the Z axis inner workings to get a better idea of how things work together as there are two sets of moving parts on a floating head. Do not mind the dirty alu part, this one is for me personally so i just need to build another smaller machine to attach this to ! :)
From above, the space is very narrow so takes a lot of time to adjust everything in place:
Same thing but inside where it belongs, notice the tight space:
Side view of that assembly, floating part moved out, or up when it is in place on the machine:
Same view with the floating part pressing on the micro switch, or material found when in use:
Same pictures as the last two but this time with the screw inserted:, bottom position, switch triggered:
Up position, switch released:
And here are two finished Z axis and two uprights for the smaller machine:
Here is how my work shop looks today:
Both machine metal parts are gone to get a new paint job, so i have 2 days to mess around with smaller stuff, or start another machine..... :)
Regards,
Tom.
  • Moderator
  • Moderator
19 May 2020 07:03 #168231 by tommylight
6 days, 3 painting jobs on them, still nothing !
They messed up everything, from not preparing the parts at all and wasting some very good paint i gave them, to painting them with some really crappy paint, to painting them blue that i do not like at all.
Might have to send them to a different paint shop, so another 3 or more days of waiting.
DAMN!
19 May 2020 07:07 #168232 by tecno
Sorry to hear that, I hope you get the job done properly.
  • Moderator
  • Moderator
19 May 2020 07:39 #168237 by tommylight
Thank you.
The main issue is sending them to "professionals", i can do a much, much better job by using spray cans ! Miserable.
19 May 2020 10:47 #168247 by phillc54
I found the same problem here when I was still working, it was getting harder and harder to find someone to do good work. ☹️
I'm glad I am retired and don't have to worry about that any more.
Time to create page: 0.423 seconds
