- Thank you received: 4153
robertspark wrote:
Code:make -j8
is actually the number of parallel operations not the number of simultaneous "files".... and the -j switch must correspond to your number of processors your hardware has.... -j8 would be for an 8 core processor....
you should run
Code:nproc
(number of processors)
before "make -j8"
or the cover all syntax would be
Code:make -j$(nproc)
that way it will always run the right number of parallel operations for your specific hardware (should you be lucky enough to have a 24 core processor....)
or like me a 2 core...
