My Grizzly G0602 Lathe
5 years 4 months ago #211958 by rodw
Replied by rodw on topic My Grizzly G0602 Lathe
Just be aware that there is a pin halui.mode.teleop that can be used to select (eg enable) the jog mode. If you set this pin when using gmocappy it will change tabs to the jog screen.
My pendant has a yellow safety button that must be pressed to jog. I use that to set this pin cos I was sick of having to walk back to the screen to select the jog screen.
Linuxcnc ignores the MPG when running programs etc.
The following user(s) said Thank You: my1987toyota
5 years 4 months ago #211981 by my1987toyota
Replied by my1987toyota on topic My Grizzly G0602 Lathe
I will definitely check into that if/when I would switch from Axis to Gmocappy.
Time to create page: 0.182 seconds
