My Grizzly G0602 Lathe
5 years 6 months ago #204697 by my1987toyota
Replied by my1987toyota on topic My Grizzly G0602 Lathe
are you looking for pics. of various parts I have anodized or the equipment ?
5 years 6 months ago #204733 by tommylight
Replied by tommylight on topic My Grizzly G0602 Lathe
Parts, parts ... :)
They always look mesmerising !
5 years 6 months ago - 5 years 6 months ago #204755 by my1987toyota
I have pics of early runs hopefully they aren't too disappointing.
Last edit: 5 years 6 months ago by my1987toyota. Reason: removing double pictures
5 years 6 months ago #204776 by tommylight
Those are the kind of pictures i like, failures included.
Green and purple ones are perfect, the others have some minor artefacts most probably due to parts not being cleaned properly. Am i in the ballpark ? :)
Thank you, much appreciated.
5 years 6 months ago #204832 by my1987toyota
spot on .
I think one of the blems was because I was using aluminum flashing for the cathode material at the time
( I don't anymore ) and small bits of plastic from the protective coating would break off and stick to the part causing
small areas to not anodize. Hence the reason I use pump circulation combined with filtration to make sure
nothing is floating around in the tank.
5 years 4 months ago - 5 years 4 months ago #211291 by my1987toyota
I finally had some time to put to the cnc lathe conversion. I had to focus on improving and expanding my Anodizing line.
My problem for a while is I have ( not by choice ) multiple projects going and sometimes I have to focus almost all my
time on one of them because my employment necessitates it. Such is life.
I had purchased a small control computer to use instead of the Dell Optiplex 7010 originally intended for this project.
The computer that will now be used is a Dell Optiplex 9020 micro . If you are interested in test results see
this forum link
forum.linuxcnc.org/18-computer/39371-res...cnc?start=240#211211
I look forward to continuing this build and doing more video's of my progress with it. Sorry in advance for
Youtube's escalating greed in that they have now forced Ads on ALL video's on their platform. I no longer have the
ability to turn them off. Nor am I financially compensated by them. I am looking for an economical replacement ,but that's item 151
of a list of a thousand different thing I need to take care of.
Last edit: 5 years 4 months ago by my1987toyota.
