What do you really get for a $350 desk top engraver ?
2 years 3 weeks ago #311363 by machinedude
Well i had some time to test cutting an arc toothed pully. I was not even sure if i could or not with a 5/8 depth on this profile. i ended up buying a special extended reach 1/16 diameter end mill to try. it does work but it is not the fastest process for sure :) i was not pushing anything very hard at all with the cost of this endmill being around $55 with tax and delivery. the bad news is i messed up with my model and offset my geometry in the wrong direction so this piece i made is no good, but the process works for sure.
2 years 3 weeks ago #311467 by machinedude
It took me 3 attempts, but the 3rd time was a charm :) It would appear to me there is a fine line between getting just enough clearance and matching the belt profile exactly. too much clearance and you end up with backlash i would guess. but i think i have a close fit or at least as close as i can get and still have things work as they should.
1 year 7 months ago #325228 by machinedude
well i have my first real issue with this build. the X axis stepper tapped out on me today. to be fair i was giving it a workout as usual :)
the funny part is i made a video and got thought the first one fine but only made it halfway through the next one :)
I'm pretty sure i stripped something out on the internal parts of the motor which is a first for me. i guess if you mess around with this stuff long enough you run into just about everything :)
1 year 7 months ago #325230 by rodw
Thats unusual. Usually, they overheat and loose steps if you push them too far and eventually stop. There isn't anything to strip really. But the temperature could exceed the safe limit and melt the insulation in the windings. What happens if you swap stepper drives?
There is something to be said for using quality motors. Try Moons Industries who you are in US.
1 year 7 months ago #325231 by machinedude
it did seem odd to me too but i did a quick search on google on mechanical failures with steppers and it said gears stripping? i never tore one apart before but i might on this one just to see the inside. when you spin it by hand it feels wrong. usually, you can feel the 1.8-degree full steps.it turns under power but it has no torque.
i got a bigger one this time of the same brand because i can have it later today. my x was a bit under powered, so this is reason to bump up a little since i can get a 3 Nm with the same frame and shaft size.
1 year 7 months ago #325232 by rodw
Great to see adoption of real engineering units in an imperial world! image missing /media/kunena/emoticons/w00t.png
The following user(s) said Thank You: machinedude
Time to create page: 0.334 seconds
