What do you really get for a $350 desk top engraver ?
2 years 1 month ago - 2 years 1 month ago #309879 by machinedude
i think what they referred to as follow error is what i was looking at as an indicator to test with if that value is set high then i can set it low to force thing to kick an alarm. that would show me which drive is doing the most correction i think so i can focus on the task in the right place and basically narrow things down some.
on small bench top or desk top size machines i have had good luck with 283 oz/in motors and those are what i have all around on this build. i was looking at bigger ones and if it would actually be an issue with 1 axis like the X i could go up to a 425 oz/in and keep the same size saft and frame size. so that could be a work around depending on where things land with testing. the drives are even the same too.
if this were open loop things would be more out in the open as far as lost steps are concerned.
added edit here. i did see about setting the dip switched to default and setting the micro stepping in the drive. that was said in the one video i found for this particular drive. so that is not an issue either.
Last edit: 2 years 1 month ago by machinedude.
2 years 1 month ago - 2 years 1 month ago #309886 by machinedude
i went back and paused that one video to take a closer look at what is going on inside the software. i think i found my adjustment needed.
the setting from the factory is 50% of the holding current. it's under closed loop holding current and has a set range of 0 to 100 % so you should be able to increase that. one thing i did notice after running the machine for 3 or 4 hours was how cool the motors were. i figured that they would has least be warm to the touch. the fact that they were still room temp still had me surprised. now i know why.
if i were to running things in open loop mode i think i would see they are getting at least warm.
i think the 50% setting is causing the correction to to kick in constantly and creates an oscillation. i think in an ideal situation they should never have to compensate so you have smooth motion but have a little extra in case you do need it.
i really do think that is my chatter problem. since i did not get in there i only have 50% because of the factory setting. i will have to find one of those cables and confirm this for sure.
2 years 1 month ago #309941 by machinedude
it turns out that you need a RS232 Adapter Cable to USB 2.0 to work with the cable they send so you. I can't get into the drive to make changes. I do not have one and had to order one so i am locked out of the drive until Friday if it comes on time.
2 years 1 month ago #310105 by machinedude
i'm wondering if Stepper-online and Leadshine are tied together somehow? the software is just about identical? anyways Leadshine  has a quick start guide for the programming software that is much more helpful than what Stepper-online has which is nothing basically. I just found the quick start guide so looks like i need to spend some time searching through that for clues. i managed to read a drive and got that part sorted out so that's a little bit of progress :)
2 years 1 month ago #310111 by spumco
Some of the Stepperonline products are re-branded Leadshine items.  Some are identical, some have firmware changes.
It's possible that the Leadshine software will work with your Stepperonline drives, but don't be surprised if it doesn't.
My SO T6 servos are rebranded LS, and while the LS software will communicate with the T6 drives, there are some software features (i.e smarter auto-tune) that are disabled in both versions of the software.
2 years 1 month ago - 2 years 1 month ago #310130 by machinedude
i'm using matching software for the Stepper- online drive's. but the quick start PDF Leadshine has goes into a lot more detail that is the information i need.at this point i have done far more reading than tinkering.
the Leadshine pdf gives you a good understanding of the layout of the software. The tree on the far left helps you sort the 8 main sections of drive settings the first main section looks to just basic info pulled for dip switch settings and the last main section if factory settings. so the main focus should be the 6 other main section and the subsections in those 6 main sections.
it looks like you might be able to record the wave form from test moves. I am guessing helps adjust the PID but that is a bit beyond my understanding at the moment.
bottom line is there is a lot of stuff going on in these drives and probably why you don't see to much on the topic.
Time to create page: 0.356 seconds
