- Thank you received: 43
You should be getting some pretty nice cuts with that one. Apart from the relatively low consumable life and a lack of spares its a great machine.I have to go pick up a Hypertherm 3070 as i do have it's torch and cables in my shop, but the transformer was to big to fit in a Skoda SuperB!
I assume you mean that the tip ”sticks out” from the torch? You could always wire the sensing between the tip and work.I do not have any torch with shield, so i can not test although i do have 2 of THCAD for now.
Yes, that is the reason i never advise using such torches with ohmic.If you have an HF start plasma, the HF is created between tip and electrode, you might still not believe me but anyways.
There could be some HF in the tip so keep that in mind.
I have my 30XP setup like that but I use a cheap solid state relay rather than a THCAD.
