- Thank you received: 907
Yes it is and that is unfortunate as the probing is done twice every time at very low speeds.
I am beating a dead horse, as i have insisted from the very start of PlasmaC that should not be implemented at all, only a single probe.
On a plate with over 200 pierces, probing time is in hours, no matter how fast the Z axis is.
It is probably an incorrect setting, my table only probes once.
This cannot happen. Ohmic sensing monitors motion.motion-type and can only activate when linuxcnc is actually probing, If its triggering, it has to be the breakaway or float switch.
Deleting the var file was a placebo. When you receive that error, it's because the ohmic probe tripped prior to reaching probe height.
That seems a bit odd as default plasmac configs don't use the LinuxNC internal probing, they usually use external offsets.
But isn't plasmac.ohmic-enable only enabled when ohmic probing? We monitor that too.
Yes, but probing is enabled from the beginning of the down motion before probe height is reached because fast probing is valid.
