- Thank you received: 4
Great news. All it took was a little tuning. Perhaps the settings that worked for me were not appropriate for a default setting. Also, many may have forgotten that the reason why the pulse torch feature was added to Plasmac was to get air flow running before the first pierce to keep water off the material on the initial probe. This was added for islander261 who adopted plasmac during the early development days. Islander261 also contributed the original ohmic relay circuit detailed here linuxcnc.org/docs/stable/html/plasma/pla...r.html#ohmic-sensingincreasing the ohmic threshold to 23.5 seems to have solved this issue for me.
After the nozzle got wet from the watertable the ohmic voltage was showing at above 22volts.
