- Thank you received: 907
Reading how much you like being on the "bleeding edge", I'm a drop curious why you didn't use the master branch? It does have a few more features that are not present in 2.9. It's also noteworthy to mention that at this point, 2.9 is considered "end of life" from a development standpoint (to include bug fixes).
Thanks. I actually asked here which version to use for production and 2.9 was recommended.
forum.linuxcnc.org/plasmac/53044-best-qtplasmac-version-to-use
I also built the 2.9.x ISOs on the Linuxcnc downloads page soi maybe I am biased. For a production setting on a machine 1800 km (over 1000 miles) away for a user, using a production version made a lot of sense.
Its not that the buildbot is broken but V2.9 is frozen following a release. Release debs for 2.9.3 are in the Linuxcnc repository which can be installed on any linux distro by running the bash script mentioned here
linuxcnc.org/docs/stable/html/getting-st...th_preempt_rt_kernel
(or by using the ISO)
Checking the release version of QTplasmac in Linuxcnc 2.9.3 , I see it is 2.9-238.314. It seems your last release for 2.9 was not included. It will probably get in there if ever a 2.9.4 is released.
I might write a script to convert from using the Linuxcnc repos to the 2.10 repos at buildbot2.highlab.com/
Anyway off topic for long enough, The main issue for us is the breakaway. It really makes no sense that it will not work when all the pins are set correctly as inputs into plasmac.comp. I will look at the state of the plasmac.comp output pins to halui as it might not be a qtplasmac issue. All of these features were working years ago so its odd they have broken.
Phil, thanks for that. It flashed through my mind to check that and I promptly forgot about it. Good Sleuthing.Do any of the issues change if you run the machine with the references to runstep.hal and/or pendant.hal commented out in the ini file?
