Absolute Encoder Questions / SSI via 5i25
- Thank you received: 5270
28 Aug 2013 21:18 #38192
Replied by PCW on topic Absolute Encoder Questions / SSI via 5i25
Right, our SoftDMC quadrature counter does count deltas in hardware so the
code just reads the count delta and adds it to the (32 bit in this case) software
maintained counter. Somehow the absolute --> relative bugs me but I guess there is really no major downside (other than a transient position read error would not get corrected)
- Thank you received: 4994
28 Aug 2013 21:29 #38193
I think it does. Consider the following sequence:
1000
1005
1010
1378 (oops!)
1020
1025
The deltas are 5, 5, 368, -358, 5.
The result of the computation is 1000, 1005, 1010, 1378, 1020, 1025.
It is very similar, in fact, to masking the lower N bits and or-ing in the new value. The difference is that in signed32 it auto-wraps into the 64-bit accumulator, (but not with variable bit)
Replied by andypugh on topic Absolute Encoder Questions / SSI via 5i25
1000
1005
1010
1378 (oops!)
1020
1025
28 Aug 2013 21:54 #38195
Thats right, its corrected the next read...
07 Sep 2013 05:08 - 17 Sep 2013 16:18 #38525
A new patch (on master from the root of LinuxCNC -dev).
Now pushed to the master branch.
I was expecting to push this to the main distribution this weekend, but I have realised that it needs to cope with configurable data fields, and that has multiplied the complexity enormously.
So, this patch will let you run encoders now, but all you get is the encoder part, and the emulated index might not work.
I think PKM has got configurable index emulation working, but so much is due to change that I didn't see the benefit in merging it now.
Unlike my previous attempts, this one has actually been tried on hardware.
Last edit: 17 Sep 2013 16:18 by andypugh. Reason: Now submitted to master.
17 Sep 2013 16:19 #38930
Now pushed to the master branch:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...b3201fa1a08657b9f69a
it should be available as part of the pre-built packages at
buildbot.linuxcnc.org
Please feed back any problems or feature requests.
BISS and Fanuc will share the same format.
