Absolute Encoder Questions / SSI via 5i25
- juwi
I can compile a 7I77 bit file some time next week
The raw interface is probably OK for the XMIT side but questionable
on receive because of common mode range. I would always want a real RS-422 driver/receiver there just for ruggedness however
Well, it would be no big thing to make a small PCB with some differential receivers on it. Or simply use a MAX491(EDITED - up to 2.5MBit) and only 2 lines from the 5i25?
@1.5MHz there is no need for advanced layouts, some basic rule obeyment should work. Only for testing of course...
Is it possible to get the Interface on the second port of the 5i25?
Thank you!
best regards,
julian
- Thank you received: 4994
That is what the 7i74 would do. It is a 25-pin D-sub to 8xRJ45 RS422 interface.[Is it possible to get the Interface on the second port of the 5i25?
(It costs $69)
- juwi
(It costs $69)
And takes 4-6 Weeks till I have it
Therefore I'd like to test with what I have till it arrives.
@PCW: It would be very nice from you to get a firmware for 7i77 to start the driver implementation
best regards,
Julian
- juwi
www.ebay.de/itm/JTAG-Programmer-Kabel-fu...&_uhb=1#ht_738wt_689
Best regards,
Julian
- Thank you received: 5270
It is worth mentioning that you only need this if it all goes wrong. You can reflash a 5i25 without any cables using the utility in the support software pack.www.ebay.de/itm/JTAG-Programmer-Kabel-fu...&_uhb=1#ht_738wt_689
- juwi
julian
- juwi
Best regards,
Julian
Yes, unless you think that using the resolver struct would suffice.@Andy: I think I must add a SSI struct to hostmot2.h?
I see no reason to use the resolver though, it might hamper you in the future.
Note that the HAL pins are kept separate as they will be hal_malloc-ed and the rest of the structure might be kmalloc-ed.
Or you can decide to hal_malloc everything, it saves a lot of garbage-collection problems.
freeby.mesanet.com/5i25_ssi.zip
Suggested SSI parameters: (in addition to the normal scaling parameters)
Bitlength (u32)
Clockrate (float)
GrayCode (bit) binary if false, graycode if true
Mask (u32) (some SSI devices have aux data in the stream you need to mask out)
in addition to the always masked MSB --> bitlength-1 in the data register
If you want me to make a config with the free SSERIAL port on a 7I77 used for SSI just ask
