Absolute Encoder Questions / SSI via 5i25
22 Aug 2013 03:38 - 23 Aug 2013 02:57 #37937 by PKM
First I connected the encoder the opposite way to yours. It responded, though only one normal response and then 0x01FFFFFF. I had to take it away from the magnetic stripe and set again, then it would give one normal response and so on.
I just switched the wires and it looks better, the normal response comes every read cycle. But I'm not sure about the binary output. Or I might decode wrong (I've made a gray_to_abs component from the wikipedia code)
gray_to_abs.comp
Not sure at all that it's correct, is unsigned ok here?
What is the simplest way to send write_strobe each servo period? I tried to connect stepgen to write_strobe but then I can't set the SSI parameters. Some switch is nesessary, it gets a bit complicated. I probably have to try connecting stepgen in postgui_hal
Last edit: 23 Aug 2013 02:57 by PKM.
25 Aug 2013 18:36 #38063 by PKM
Great news! I will try it asap, hopefully today or tomorrow.
25 Aug 2013 22:44 - 25 Aug 2013 22:45 #38074 by PKM
No abs_encoder in rtlib.
Make log:
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
/home/pkm/linuxcnc-dev/src/hal/drivers/mesa-hostmot2/abs_encoder.c: In function `hm2_absenc_parse_md`:
/home/pkm/linuxcnc-dev/src/hal/drivers/mesa-hostmot2/abs_encoder.c:147: warning: passing argument 2 of ˜`hal_export_funct` from incompatible pointer type
/home/pkm/linuxcnc-dev/src/hal/hal.h:621: note: expected void (*)(void *, long int) but argument is of type `˜void (*)(struct hostmot2_t *)`
Last edit: 25 Aug 2013 22:45 by PKM.
25 Aug 2013 23:24 #38075 by andypugh
Replied by andypugh on topic Absolute Encoder Questions / SSI via 5i25
That's only a warning, it shouldn't matter.
Are you running installed or run-in -place?
Don't forget the sudo make install or the . ./scripts/rip-environment.
25 Aug 2013 23:33 #38076 by PKM
I use run-in-place. But just no abs_encoder in rtlib folder, and loadrt abs_encoder causes error
5i25_7i76.hal:9: Can't find module 'abs_encoder' in /home/pkm/linuxcnc-dev/rtlib
Sure I did everything.
./autogen.sh
./configure --enable-run-in-place
make
sudo make setuid
linuxcnc
The patch was OK, at least there's abs_encoder.c in its folder, abs_encoder strings in src/makefile.
25 Aug 2013 23:58 #38078 by andypugh
It is part of the Hostmot2 driver.
Try loadrt hostmot2 then loadrt hm2_pci
With the firmware PCW posted you should find some
Hm2_5i25.0.absenc... Pins.
26 Aug 2013 00:22 #38080 by PKM
Actually I first tried adding
addf hm2_5i25.0.trigger_encoders servo-thread
and received error
HAL: ERROR: function 'hm2_5i25.0.trigger_encoders' not found
5i25_7i76.hal:12: addf failed
And then I thought addf needs loadrt and started that loadrt abs_encoder thing.
Without addf it starts, I see absenc 00 and 01.
I'll try to set some parameters now.
26 Aug 2013 02:00 - 26 Aug 2013 02:09 #38085 by PKM
OK, I started config with
addf hm2_trigger_encoders servo-thread
and I'm flooded with popping errors
hm2/hm2_5i25.0: Data transmission not complete before encoder position read. You may need to place the absenc_trigger function earlier in the thread
Also, I can't find absenc.num_instances parameter in the tree.
upd: Looks like it's hm2_pci call parameter num_absencs
Last edit: 26 Aug 2013 02:09 by PKM.
26 Aug 2013 02:40 #38087 by PKM
I've set some parameters
setp hm2_5i25.0.absenc.00.bit-length 25
setp hm2_5i25.0.absenc.00.frequency-khz 50
setp hm2_5i25.0.absenc.00.gray-code 1
Still flooded with earlier-in-the-thread errors, so the machine starts 30 seconds.
And looks like no actual readings from the encoder.
Other settings nesessary?
26 Aug 2013 03:20 #38090 by PCW
50 KHz is _way_ too slow especially if you expect the SSI read to be
finished by the end of the other hostmot2 reads (24 bit x 20 usec = 480 uSec!)
In fact my encoder will not even read at that rate as the
SSI reset time is ~20 usec so it just resets every clock
