Absolute Encoder Questions / SSI via 5i25
- Thank you received: 5187
17 Aug 2013 02:14 #37764
Replied by PCW on topic Absolute Encoder Questions / SSI via 5i25
No smart serial commands will work (SSI stands for Synchonous Serial Interface) It is a very simple way to communicate with absolute encoders.
The hardware works like this: on command the host sends out a burst of clock pulses and the encoder responds with a serial data stream of position data
(often in gray code)
raw-read/raw-write hm2 interface is very low level, you can just read/write physical registers.
This is enough to verify SSI interface operation (in conjunction with the register information for the SSI interface) but not a lot more
Earlier it this thread I detailed what I thought was required of a flexible SSI interface (bit field extraction, gray code conversion) etc
- PKM
- Thank you received: 3
17 Aug 2013 02:17 #37766
by PKM
The type of transmission protocol is "right aligned" with a length of 25 bit. The transmission starts with MSB (most significant bit) and ends with LSB (less significant bit). Unused bits are set to 0 (zero). The output code of the sensor is GRAY.
Besides clock and data pins, it has inputs for zeroing and reversing. Though I could live without those.
That is the driver has to provide clock signal, read 25 bit reply and convert it from Gray code.
Replied by PKM on topic Absolute Encoder Questions / SSI via 5i25
I have a linear encoder, but almost the same specs:The clock input/data output are normally just 5V RS-422 but you should check the data sheet. The encoder I have is the same :10-30V power RS-422 input and output levels. Mine happens to be 12 bits of counts per turn and 12 bits of turn counts, both in gray scale
- PKM
17 Aug 2013 05:13 #37769
by PKM
Do I need the firmware that you made earlier in this thread?
Can you give me the commands that you use to communicate with your encoder? I'll have it on 7i76 (or 7i77 if nesessary) port.raw-read/raw-write hm2 interface is very low level, you can just read/write physical registers.
- Thank you received: 4966
17 Aug 2013 05:25 #37770
You need to enable raw mode: www.linuxcnc.org/docs/html/man/man9/hostmot2.9.html#Raw%20Mode
And then you can access the registers directly: git.linuxcnc.org/gitweb?p=hostmot2-firmw...a660c71a48191b4d1a64
It's not especially user-friendly
Replied by andypugh on topic Absolute Encoder Questions / SSI via 5i25
- PKM
17 Aug 2013 13:16 - 17 Aug 2013 17:29 #37773
by PKM
Really it isn't... but I start figuring it out. What I was most scared of is low-level SSI communication (sending a clock sequence and reading the reply), but I see that hm2 does that with Simple SSI interface.
Say I connected the encoder to 7i76. Now it's on SSI data register 0?
The following is my guess:
I need to set the number of encoder bits (25) and probably set program start mask to SSIBitCountRegister 0, that is
setp hm2_5i25.0.raw.write_address 0x6900
setp hm2_5i25.0.raw.write_data 89 (25 to 0...5 bits and 1 to bit 6 for Program Start Mask)
setp hm2_5i25.0.raw.write_strobe 1
SSI Bit Rate register should be set. CLockLow is 50MHz for 5i25.
The encoder has a frequency of data transmission from 100 kHz to 1 MHz, it must be the Shift frequency.
Then for 500kHz I need to set SSI Bit Rate register to 65536*500000/50000000 = 655
setp hm2_5i25.0.raw.write_address 0x6A00
setp hm2_5i25.0.raw.write_data 655
Then I have 2 ways to start the reading cycle: either write (anything?) to SSI Global Start register (as the Program Start Mask is set to 1) or write (anything?) to SSI data register 0
Say I choose the second way (which is not logical as I just set the program start mask bit):
setp hm2_5i25.0.raw.write_address 0x6800
setp hm2_5i25.0.raw.write_data 1
To see the returned value:
setp hm2_5i25.0.raw.read_address 0x6800
show pin hm2_5i25.0.raw.read_data
Please check if that's correct
Last edit: 17 Aug 2013 17:29 by PKM.
17 Aug 2013 19:34 #37780
Looks about right, does it work?
- PKM
17 Aug 2013 19:55 #37782
by PKM
I'll check that on Monday... occasionally left the encoders at my office.
If that proves to work, is it possible to make a thread to start the reading cycle, then connect the hm2_5i25.0.raw.read_data to some "grey-to-abs" component (probably not so hard to make) and have the encoder working?
17 Aug 2013 23:11 - 18 Aug 2013 00:53 #37783
One detail left out is is that the DDR and AltSrc register bits for the clock output pin would need to be set to one (since the driver does not know about the SSI tags)
Also if you use the latest firmware source, the SSI registers have changed:
The max data length has been extended to 64 bits to allow double-reading
for data verification, so the control reg has moved to 0x6A00
included here:
is a up-to-date regmap file and example program source
for reading the encoder
included here:
Last edit: 18 Aug 2013 00:53 by PCW.
- PKM
18 Aug 2013 03:31 #37786
by PKM
I looked through 7i76 manual, there are SS0TX (IO10) and SS1TX (IO12) pins, which is used for RS-422 interface on TB3?One detail left out is is that the DDR and AltSrc register bits for the clock output pin would need to be set to one (since the driver does not know about the SSI tags)
- PKM
19 Aug 2013 18:46 #37843
by PKM
I'm trying the above described, but nothing for now. Even no clock sequence on the scope.
When setting 0x6A00 it remains the same 0xFFFFFFFF (while 0x1100 changes when I write to it). What should be the default value for 0x6A00?
I purchased 7i76-5i25 PnG kit on June 2013, is it possible that the firmware has no SSI? The latest 7i76x2.bit is dated 2013-02-22, so I guess my card should have it?
Time to create page: 0.174 seconds
