- Configuring LinuxCNC
- Advanced Configuration
- Preparation for the self-construction of a carousel changer
- Thank you received: 4656
03 Nov 2022 18:30 #255877
Yes. Try that with the current firmware, in fact just delete that num_pwmgens=0 and it will enable all of them (if there are any)
Replied by andypugh on topic Preparation for the self-construction of a carousel changer
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=20xxxx"
I think I need to change num_pwmgens=0 to num_pwmgens=1 right?
- mgm
- Thank you received: 13
04 Nov 2022 07:52 #255908
by mgm
Replied by mgm on topic Preparation for the self-construction of a carousel changer
For each bit file there is also a pin file or?
Unfortunately I can't find the pin file for the bit file "7i76e_7i76x1p2d.bit". It is not in the zip file at mesa!
I would like to have a look before I write the file.
If I write the file will all my current assignments be preserved or do I have to change something afterwards?
Because the machine is already in use!
04 Nov 2022 08:37 - 04 Nov 2022 08:38 #255912
The pin file (PIN_7i76x1P2D_51.vhd) is in the zip file that I have, but if you are using all 5 stepgens that is no use to you anyway:
Start LinuxCNC from the command-line without num_pwmgens=0 and see what you have already. That's going to be least dangerous option id there are pwms on the expansion ports.
IOPortTag & x"00" & StepGenTag & StepGenDirPin, -- I/O 00 embedded 7I76
IOPortTag & x"00" & StepGenTag & StepGenStepPin, -- I/O 01
IOPortTag & x"01" & StepGenTag & StepGenDirPin, -- I/O 02
IOPortTag & x"01" & StepGenTag & StepGenStepPin, -- I/O 03
IOPortTag & x"02" & StepGenTag & StepGenDirPin, -- I/O 04
IOPortTag & x"02" & StepGenTag & StepGenStepPin, -- I/O 05
IOPortTag & x"03" & StepGenTag & StepGenDirPin, -- I/O 06
IOPortTag & x"03" & StepGenTag & StepGenStepPin, -- I/O 07
IOPortTag & x"01" & PWMTag & PWMAOutPin, -- I/O 08
IOPortTag & x"00" & PWMTag & PWMAOutPin, -- I/O 09
IOPortTag & x"00" & SSerialTag & SSerialTX0Pin, -- I/O 10
IOPortTag & x"00" & SSerialTag & SSerialRX0Pin, -- I/O 11
IOPortTag & x"00" & SSerialTag & SSerialTX1Pin, -- I/O 12
IOPortTag & x"00" & SSerialTag & SSerialRX1Pin, -- I/O 13
IOPortTag & x"00" & QCountTag & x"03", -- I/O 14
IOPortTag & x"00" & QCountTag & x"02", -- I/O 15
IOPortTag & x"00" & QCountTag & x"01", -- I/O 16Start LinuxCNC from the command-line without num_pwmgens=0 and see what you have already. That's going to be least dangerous option id there are pwms on the expansion ports.
Last edit: 04 Nov 2022 08:38 by andypugh.
- mgm
04 Nov 2022 10:04 - 04 Nov 2022 10:05 #255918
by mgm
Ok I now removed num_pwmgens from hal and started linuxcnc in terminal and then got the following:
OK there are no PWMgens available and now?
Where do I get some? and how does the 7i74 help?
Last edit: 04 Nov 2022 10:05 by mgm.
04 Nov 2022 11:07 #255931
So, you need to find a suitable firmware which matches the 7i76 on P1 but has PWM on P2.
The 7i74 will plug into the P2 (or P3) connector and protect the bare FPGA pins from static, undervoltage, overvoltage etc. And provide screw terminals for the wires.
- mgm
12 Nov 2022 12:17 #256516
by mgm
small update:
i now have pwmgens on the extension P1 and the 7i74 connected
What I use for a bitfile is in this topic:
forum.linuxcnc.org/27-driver-boards/47310-mesa-7i76ed-extension
Must now find out what all I need to control via pwm in the hal and how to connect it to the driver!
- mgm
14 Nov 2022 05:51 - 16 Nov 2022 08:04 #256679
by mgm
Could someone please look if this is correct?
connection from BLDC to 7i75 or to P1 of 7i76e
to use the PWM I add the following lines to my hal?
loadrt pwmgen output_type=0
addf pwmgen.make-pulses base-thread
setp pwmgen.0.pwm-freg 1000.0
setp pwmgen.0.scale xxx
is there anything missing except the assignment to the PWM output?
These half entries are for the software PWM!
For me these are not necessary ...
Last edit: 16 Nov 2022 08:04 by mgm.
15 Nov 2022 18:09 #256819
Try it. Worst case it just won't work.
- mgm
16 Nov 2022 08:07 #256861
by mgm
it works !
The PWM connection from the 7i75 to the BLDC 8015A is as follows:
Pin 7i75 Pin BLDC
PWM / IO0 to AVI
G to GND
I need these entries in the hal:
setp hm2_7i76e.pwmgen.00.pwm_frequency 1000
setp hm2_7i76e.pwmgen.00.value 0.025
setp hm2_7i76e.pwmgen.00.enable true
I switch the motor on and off via the enabl pin at the BLDC 8015A therefore pwmgen.00.enable true!
Pin 7i75 Pin BLDC
PWM / IO0 to AVI
G to GND
- mgm
29 Nov 2022 07:10 - 29 Nov 2022 07:29 #257969
by mgm
So I am currently busy with the carousel.comp , unfortunately I am in the meantime only despair ......
The description says:
"When the enable pin is set to true the component will immediately set the "active" pin to true"
and this does not happen with me, why? what have I forgotten ...
I have collected the following hal-components:
loadrt carousel pockets=12 dir=1 encoding=BCD num_sense=4
loadrt conv_float_s32
addf carousel.0 servo-thrad
addf conv-float-s32.0 servo-thread
setp carousel.0.fwd-dc 0.025
setp carousel.0.rev-dc 0.025
net car-enable motion.digital-out-10 carousel.0.enable
net car-pos-req motion.analog-out-00 conv-float-s32.0.in
net car-pos-s32 conv-float-s32.0.out carousel.0.pocket-number
net bit0 carousel.0.sense-0 hm2_7i76e.0.7i84.0.1.input-19-not
net bit1 carousel.0.sense-1 hm2_7i76e.0.7i84.0.1.input-20-not
net bit2 carousel.0.sense-2 hm2_7i76e.0.7i84.0.1.input-21-not
net bit3 carousel.0.sense-3 hm2_7i76e.0.7i84.0.1.input-23-not
net car_rad carousel.0.strobe <= hm2_7i76e.0.7i84.0.1.input-22-not
net T-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change iocontrol.0.tool-changed
I proceed as follows:
For test purposes
- I set the pocket-number in MIDI via M68 P0 Qxx
- then I set the enabel pin with M64 P10
but the activ pin is not true .....
For test purposes
Last edit: 29 Nov 2022 07:29 by mgm.
Time to create page: 0.270 seconds
