Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 8 months ago #87603 by PCW
For initial testing, its best that you do not connect any I/O (encoders etc) to the 7I77
Is 7I77 CR1 illuminated?
What voltage do you measure at 7I77 TB1?
Are 7I77 jumpers W4 and W12 in the left hand position?
Is the 7I77 connected to the 5I25 cards P3 (DB25) connector with a IEEE1284 cable?
9 years 8 months ago #87604 by andypugh
Not a problem, but are you actually using the parallel port?
I am still wondering why we are not seeing any active sserial pins showing in the dmesg. But I have never used a 7i77, so don't know what you would expect to see.
9 years 8 months ago #87607 by tommylight
andypugh wrote: Not a problem, but are you actually using the parallel port?
I have installed 2 of them (7i77) and i was wondering the same thing. Conned through all that dmesg but could not find anything wrong. The pinout in the Linuxcnc error report was a bit off.
But knowing PCW is always here, i refrain myself from commecting on things i do not have at least a certain degree of certenty, so i just read and learn.
9 years 8 months ago - 9 years 8 months ago #87612 by new2linux
Many many thanks PCW, andypugh and tommylight for your help, thoughts or other.
PCW asked the following: the responce
Is 7I77 CR1 illuminated? yes
What voltage do you measure at 7I77 TB1? 5 v
Are 7I77 jumpers W4 and W12 in the left hand position? yes to the left
Is the 7I77 connected to the 5I25 cards P3 (DB25) connector with a IEEE1284 cable? molded on cable IEEE1284
this is a most current (after reboot hal 121)
Warning: Spoiler!
Debug file information: Note: Using POSIX realtime ./1st_LinuxCNC_Bridgeport.hal:121: parameter or pin 'hm2_5i25.0.encoder.03.counter-mode' not found 2857 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components RTAPI_PCI: Unmapped 65536 bytes at 0xb6fba000 Note: Using POSIX realtime
Warning: Spoiler!
many thanks for any of your thoughts, point me in the best direction, if i need more preferred reading!
Last edit: 9 years 8 months ago by andypugh. Reason: Added spoiler tags (code tags don't work any more)
9 years 8 months ago #87618 by tommylight
Now we're coockin !!!
Now you are on the right track, as it is communicating with 7i77 and finding the analog outs. It just looks like you do not have any encoder connected to encoder port 4. You can just ommit that line and move on, until you connect the encoder to that line.
Try that and report back.
9 years 8 months ago - 9 years 8 months ago #87619 by PCW
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
shows that it should be all working now
your configuration has an error:
config string '0 out'
possibly a leftover from a a parallel port configuration
also rather than dump of all of dmesg here
Just start linuxcnc from a terminal window and post the error messages in the terminal here
Last edit: 9 years 8 months ago by PCW.
Time to create page: 0.267 seconds
