- Thank you received: 7491
Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 8 months ago #88082
Replied by tommylight on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Later, need lots of food.
- new2linux
- Thank you received: 9
9 years 8 months ago #88090
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
tommylight, if you were to give me the correct address for delivery and what you wanted from the takeout menu, I would hook you up!
tommylight wrote: Later, need lots of food.
9 years 8 months ago #88108
Sorry bro, fell asleep after two days of work with just 20 minutes of sleep in a car driving to a work site.
You should also follow Dan's thread as he is dealing with the same things on his machine.
Tuning will not work from pcconf, so make a config that roughly meets your needs, and save it. Tuning has to be done from Linuxcnc running.
First make sure you have encoders right, then servo enables working from Linuxcnc, one by one not all at the same time. Tuning also one by one drive. Never all at the same time.
- new2linux
9 years 8 months ago #88109
by new2linux
tommylight, you are 100% good with me, many thanks for ALL your help! I will follow your directions as well as with Dan. Just to show the current situation, I have 2 screen shots of the area that seems to have things I can't seem to edit, or just not completely shore how to edit. One of these screenshots is taken from "halrun" to access the screen in question. All the future edits are to be done in a "text editor" on .ini and .hal files after using wizard to get close as possible.
The Realtime function not linked screen needs the "Thread" "Period" (in the center of screen) needs to have some values in that area.
The other screenshot as the axis (2 axis are identical) I need editing (low to left of shot).
Many thanks for any help or suggestive reading to aid in my effort would be greatly appreciated!!
- Thank you received: 1480
9 years 8 months ago #88110
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Halscope requires that a realtime thread is running, So to run it from halrun, there are a number of things that have to be set up first. The second screen shows that you don't really have anything running in hal to test. All that is taken care of if you start it from within a running Linuxcnc session.
9 years 8 months ago #88151
I am currently writing a detailed how to for tuning with use of halscope included, hopefully i will have a rough outline by tomorrow night. Need a lot of screen shots and other info gathered, i did some outlines and some preparatory informations tonight.
Time to create page: 1.163 seconds
