Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 8 months ago #87667 by new2linux
PCW Many thanks! The linux is on a computer that is not connected to the internet, so a memory stick is the way it works. I have used the copy and past to get a file (in a text editor) saved on the linux machine usb stick and go to win 10 machine for internet. Now at this point I can attach if I add the .txt to the file name (as seen below) or it appears to be copy and paste, like what I was doing here. So maybe try attachment for change, please comment.
tommylight many thanks to you as well for your thought and encouragement!
If I do not have 110 v power on the error code will be 56.
IF power up the 121 code is displayed as the files show.
9 years 8 months ago #87669 by andypugh
What is your "num_encoders" set to?
9 years 8 months ago #87671 by new2linux
Many many thanks andpugh!!
num_encoders=3 as per .hal file
thanks!
9 years 8 months ago #87676 by PCW
That's why you have "hm2_5i25.0.encoder.03.counter-mode not found"
You have only enabled encoders 0,1,2
9 years 8 months ago #87678 by new2linux
Many many thanks!
I have pondered what andypugh and PCW are suggesting and that would be to edit to 2 from the existing 3. I try to restrain myself, without confirmation will not go backward in progress if possible. Again I offer my many thanks to all that help make this happen.
9 years 8 months ago #87680 by PCW
Theres no reason not to enable all encoders (num_encoders=6)
Time to create page: 0.160 seconds
