Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 8 months ago #88168 by new2linux
tommylight, you are the best! a complete and total gentleman all the way thru! Many many thanks!
9 years 8 months ago #88180 by lakeweb
I'm Dan, the Eagle conversion. I thought I would follow along here as I just went through this. Have you gotten LinuxCNC to launch yet?
9 years 8 months ago #88199 by new2linux
Dan, thanks for your interest, your project looks great! Keep up the good work. I have read thru your project, and followed along, I have just got to a point where I am somewhat stuck. I cut/paste the errors from a linuxcnc launch, I just not shore what to be looking for.
emc@cnc ~ $ linuxcnc
LINUXCNC - 2.7.8
Machine configuration directory is '/home/emc/linuxcnc/configs/1st_LinuxCNC_Bridgeport'
Machine configuration file is '1st_LinuxCNC_Bridgeport.ini'
Starting LinuxCNC...
Found file(REL): ./1st_LinuxCNC_Bridgeport.hal
Note: Using POSIX realtime
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:04:04.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:04:04.0
Found file(REL): ./custom.hal
USRMOT: ERROR: invalid command
Linear move on line 11 would exceed joint 2's positive limit
this is where I am, any help would be greatly appreciated!!
  • Moderator
  • Moderator
9 years 8 months ago #88200 by tommylight
That means you can start Linuxcnc, but can not run a gcode program, right?
That error means that you have gcode going in negative direction, or to far in positive direction, OR that you do not have the ini settings as they should be for your machine.
In the in you have for each axis values for :
MIN_LIMIT = -100 <=== change this
MAX_LIMIT = 2000.0 <=== change this
you have to do that twice for each axis, if you are using 2.8pre, only once per axis if using 2.7 or earlier version of linuxcnc.
9 years 8 months ago #88203 by new2linux
tommylight, many thanks to you!! I still can't get the servo to run under power. I have disconnected the other servo as to just work the one at a time.
Thanks for your help!
9 years 8 months ago - 9 years 8 months ago #88208 by lakeweb
So you can hit the E-Stop and hit the servo button and the control panel ungrays? No errors in the lower right? The panel has to ungray out to be up and running. If it is and you jog and the table doesn't move, you should absolutely get an error.
Update: and I checked, it would be a joint 0 following error
Best, Dan.
Last edit: 9 years 8 months ago by lakeweb.
Time to create page: 0.264 seconds
