Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 8 months ago #87694 by andypugh
new2linux wrote: I have pondered what andypugh and PCW are suggesting and that would be to edit to 2 from the existing 3.
Ponder some more ;-)
You need num_encoders to be 4 to enable encoders 0,1,2,3
But, as PCW says, there isn't any reason to disable any of them.
9 years 8 months ago #87697 by new2linux
Many thanks PCW and andypugh, attached are dmesg, .ini and print error files. Again I ponder, "axes.3.motor-pos-fb" I see this line, 7 lines above the # AXES Z in the .hal files. The only thing I see that maybe the issue is the 3 needs to go to 03, as to match the other code in that area. just a guess. unless this like before and needs to go to 6.
Many thanks for everyone's help especially PCW, andypugh, tommylight and bevins, I would not be this far without your help!!
9 years 8 months ago #87699 by tommylight
You have to change the config for X and Y axis, just replace anything pertaining to axis 2 to axis 1 and axis 3 to axis 2, also encoders and analog ouuts.
9 years 8 months ago #87700 by tommylight
There should be axis 0, 1 and 2. You have them as 0,2,3
9 years 8 months ago #87702 by new2linux
tommylight I have from earlier posted this:
I have swapped encoder 0 & 1 "went to" encoder 2 & 3 located at TB3 & TB4; in addition to the associated DRV 0 & 1 "went to" DRV 2 & 3.
The thinking behind my approach was the layout of the 7i77 card calls out the location, to match to .hal file. If this is not the correct way and it recognizes 0,1,2 no matter location on 7i77 card will gladly rework.
many thanks!!
9 years 8 months ago #87704 by tommylight
Found it, you havee that line in the motor.1 section, just change the 3 in that line to 1
Time to create page: 0.200 seconds
