Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 5 months ago #92530 by andypugh
Yes, max-accelleration and max-velocity are per-joint parameters in the INI file.
9 years 5 months ago #92532 by Todd Zuercher
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Yes simply change the MAX_ACCELERATION = N, under each [AXIS_N] heading in your ini file to a smaller number. From the looks of your Halscope plot I would guess it should be about 2/3-1/2 as large as it is now. I thought I had suggested this earlier but first I thought you should confirm that there wasn't a setting in the drive that was limiting your acceleration before resorting to dialing back the acceleration.
9 years 5 months ago #92542 by new2linux
Todd, thanks for your help!!
Only if the bus voltage could be increased, I believe, and 75 is max.
many thanks!
9 years 5 months ago #92543 by new2linux
Many, many thanks!
This is most recent hal trace of "y" axes. This was at 60"/min and max acceleration is at .9 (from 1.0). I will try .8 to see how much changes.
many thanks!
9 years 5 months ago - 9 years 5 months ago #92544 by Todd Zuercher
When you make changes to the ini file with a text editor. You have to exit Linuxcnc and restart it for those changes to take effect. (It doesn't look like your acceleration is changing.)
You can make temporary changes to an axis' max_acceleration while Linuxcnc is running by using halcmd (either from the command prompt or the Hal Config window) to setp the pin ini.N.max_acceleration to a new value (N=the axis number)
Last edit: 9 years 5 months ago by Todd Zuercher.
9 years 5 months ago #92549 by new2linux
This is the last screenshots with .7 velocity and 25.0 acceleration:
with .8 velocity and 25.0 acceleration:
with .9 velocity and 25.0 acceleration:
I plan to try tomorrow, and fresh, use restart each time.
Many, many thanks!!
Time to create page: 2.170 seconds
