Retrofitting a 1986 Maho MH400E
6 years 9 months ago #154940
They look very similar too:
www.ame.com/clamping-sleeves-al-il
www.spieth-maschinenelemente.de/en/the-principle/
Says that they can be released and re-used at any time.
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
J Green wrote: My 600E uses SPETH clamping sleeves type DS but noted that "Spieth" has a Type AK / IK an AL / IL clamping sleeve that may be what was used in your 400.
The following user(s) said Thank You: J Green
- RotarySMP
- Thank you received: 595
6 years 9 months ago - 6 years 9 months ago #154942
by RotarySMP
Good choice on the 7i73 for the pendant. I did it the hard way, with discrete wiring, so that project is stalled till I get 5m 20x wire and pull it through the conduits between the control cabinet and user module. A bunch of metal covers need to come off. Kind of figure that that job will happen at the same time as the move.
Without an automatic tool changer, the hydraulic pump on my MAHO only runs when you push the tool release button. Takes a couple of seconds to build up pressure, but with a manual tool change that couple of seconds makes no difference.
Norbert helped me out with setting up the tool length sensor INI, so it is now functional.
forum.linuxcnc.org/gmoccapy/38034-setup-...not-defined?start=20
Haven't used the MAHO since, so I still need to work through the work flow aspects of actually using it.
The lathe thing is a little embarrassing. More of toy. Before we got a house, we lived on the third floor of an inner city apartment. My very tolerance SWMBO tolerated my need for a workshop, when a chinese 7x12 minilathe got put it on the balcony.
www.wrathall.com/Interests/machining/My_shed.htm
CNCing it was partly to be able to enclose it and keep swarf out of the kids feet.
Since I got the house and the Boley, the minilathe lurked in the corner, abused for just a couple of wood turning jobs.
Then came the Coborn scraper and the need to learn to scrape has been an itch which was largely ignored but keeps breaking out. Before I ruin a real machine hacking away at it, the poor minilathe will be slowly converted to iron filings.
The CNC conversion was done years ago with steppers, a cheap break out board and TurboCNC. Since the Boley has no change wheels, the minilathe will again be CNC controlled. The controller is going to be pretty compact, with a tiny computor (Gigabyte SBC), little 10" touch screen, and Mesa 7i96. Making Videos is kind of fun, so this build will be in youtube.
Dont hold you breathe though. Project progress is glacial in my shed. It took seven years to finish the bend brake.
www.cnczone.com/forums/bending-forging-e...on-/56672-forum.html
Mark
Mark
Last edit: 6 years 9 months ago by RotarySMP.
- drimaropoylos
- Thank you received: 40
6 years 9 months ago #154948
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
- RotarySMP
6 years 9 months ago #154950
by RotarySMP
Thanks. I forgot about that thread.
Mark
Mark
- JANNOVV
- Thank you received: 7
6 years 9 months ago #154951
by JANNOVV
Replied by JANNOVV on topic Retrofitting a 1986 Maho MH400E
MAHO ZUBEHOR
The following user(s) said Thank You: akb1212, J Green
- JANNOVV
6 years 9 months ago #154952
by JANNOVV
MAHO ZUBEHOR 2
Moderators: piasdom
Time to create page: 0.961 seconds
