Retrofitting a 1986 Maho MH400E
24 Jan 2020 20:02 - 25 Jan 2020 09:52 #155671 by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi there,
did some little adjustment to the table.
It was almost perfect just sitting in the fitting-keys.
The cleaning of the contact surfuces really did it.
cloud.monschan.de/index.php/s/xzb9BMs4T2wRaKi
cloud.monschan.de/index.php/s/yH5qHWQ7cepm8Ap
First fit:
The original plastic nut literally turned to dust.
Don't know if it is correct, but I made the thread M38x1.5
Last edit: 25 Jan 2020 09:52 by hanmon.
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Jan 2020 23:00 - 24 Jan 2020 23:07 #155700 by RotarySMP
Hi Bob,
Don't get too excited, I doubt my draft HAL/INI will work without editing and correcting,
Hi Hanno,
Nice progress. I get bad gateway errors on the two links you sent though.
I was machining some aluminium spacers for a friend today. Haven't cleaned the chips out of the try for a while, and the mesh got clogged so the coolant overflowed onto the floor. What a mess.
Mark
Last edit: 24 Jan 2020 23:07 by RotarySMP.
24 Jan 2020 23:19 - 25 Jan 2020 00:08 #155701 by hanmon
yeah...having trouble with the (my) server...
edit:...fixed
Last edit: 25 Jan 2020 00:08 by hanmon.
  • RotarySMP
  • Platinum Member
  • Platinum Member
25 Jan 2020 11:32 #155719 by RotarySMP
Thanks Hanno, now it worked. You can't argue with those numbers. Hard to argue with zero!
One of my friends had me mill a couple of spacers for him yesterday. I made a video of it.
Mark
25 Jan 2020 13:52 #155721 by hanmon
Hi Mark,
your videos are really nice. Tutorial like,entertaining, showing the essence of your work. Exactly how I like them on youtube.
It is almost zero, more like 0,005mm which seem to be the factory tolerance.
The table and the X-axis are perfect now according to my estimation.
Does anyone know the specs MAHO delivered their machines with?
How are the specs on such machines, generally ?
Z is hard to measure, as the weight continuosly pushes down but stabilizes on the other hand.
Y is easy like X and I will adjust it soon.
I'm currently connecting the A-Axis and tuning the Servo-Controller.
25 Jan 2020 15:32 #155726 by db1981
Replied by db1981 on topic Retrofitting a 1986 Maho MH400E
Hello,
an old Maho Man told me 0.01mm is already an bad condition....
25 Jan 2020 15:34 #155727 by db1981
This browser does not support PDFs. Please download the PDF to view it: Download PDF
25 Jan 2020 15:39 #155728 by db1981
The following user(s) said Thank You: RotarySMP, drimaropoylos
  • RotarySMP
  • Platinum Member
  • Platinum Member
25 Jan 2020 15:57 #155729 by RotarySMP
Thanks Hanno. I guess I'll have to run a clock over my table now to compare. Also have to clean out the coolant drain.
Mark
25 Jan 2020 16:46 #155734 by hanmon
THX db1981 !!!!
Moderators: piasdom
Time to create page: 0.421 seconds
